Author: Subject: Anyone know about Alfa's?!
SALAD
posted on 12/7/06 at 02:57 PM Reply With Quote
Before we resort to torching the bast@rd Alfa I though I'd ask you chaps.
I'm attempting to exorcise my mate's P reg Alfa Romeo GTV 2.0l 16v
He was told that the starter motor had gone and after spending thousands on various parts (including a recon head!)
you would hope that the engine is sorted now.
However, upon putting a new battery on it, she turned over (so not the starter motor then), but had no spark.
I got the master keys from him to see if re-programming the immobiliser would make a difference.
I've been on an alfa forum and got the sequence of key turns etc with the master keys.
From memory the sequence goes something like....
1. Insert red master key and turn to MAR untill CODE light comes on
2. within 10 seconds insert normal key and turn to MAR untill CODE light goes out
3. repeat with all other keys
4. Insert red key again and turn to MAR....etc
Problem is the CODE light doesn't come on at all.
If it was always on then I'm guessing that means the immobiliser is stuck on, but not coming on at all then....??
If the fact the CODE light doesn't come on means the immobiliser is off, then we still have the problem of no spark.
Any ideas before more money gets spent or it 'accidently' catches fire?!
(I hope that makes sense)
Edit: After being on the phone to various people, it would appear that it needs to go have a check up on an Alfa computer.....I think it may catch fire before then....ooops!
[Edited on 12/7/06 by SALAD]
mookaloid
posted on 12/7/06 at 03:01 PM Reply With Quote
You could try asking here
http://www.alfaowner.com
They seem a friendly bunch
SALAD
posted on 12/7/06 at 03:08 PM Reply With Quote
That's where I found the key sequence Mook, and yes they do seem a friendly bunch!
Looks like it needs to be plugged in to the computer though.
mookaloid
posted on 12/7/06 at 03:25 PM Reply With Quote
Ah well it was worth mentioning....
They do seem to go on about Alfa electrics a lot for some reason though
zetec
posted on 12/7/06 at 03:40 PM Reply With Quote
The very sort of reason my wifes GTV had to be sold. Good looks bad reliability! 40,000 miles and the type of problems my old Focus does not have at 120,000 mile!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
muzchap
posted on 12/7/06 at 04:28 PM Reply With Quote
Torch it Torch it !
My mates just done his bottom end. they want around £400-£600 for a 2.0 16v engine on a 155.
You can get a brand new 2.3 Duratec for £800.00 go figure!
Alfa's should be scrapped - they are rubbish IMHO
Want to do a quick deal on the bottom end tho?
[Edited on 12/7/06 by muzchap]
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
SALAD
posted on 12/7/06 at 05:13 PM Reply With Quote
If the 'computer says NO' then the bottom end will be available to you muzchap.....thats if it survives the fire bombing!
theconrodkid
posted on 12/7/06 at 06:43 PM Reply With Quote
alfa,s are wicked cars,anyone found harming one will get a visit from the boys in black
who cares who wins
pass the pork pies
SALAD
posted on 12/7/06 at 07:26 PM Reply With Quote
Fancy purchasing it Mr Kid, you know, take it under your wing.
You and the boys in black could fix her!
