RazMan
| posted on 27/7/06 at 05:27 PM |
Towbar height?
Can anyone tell me the recommended towbar height for a car transporter trailer (SVA soon .... oooooh). I just want to make sure I'm ok before
hiring a trailer.
Raz
DIY Si
| posted on 27/7/06 at 05:30 PM |
Just drive it there! Gives a chance to bed the brakes in etc, and if you think it'll pass (bar a few missing bits of trim and so on) you should
be confident enough to trust it.
RazMan
| posted on 27/7/06 at 05:37 PM |
That's my dilemma - I need to get the geometry set up (corner weights, tracking etc) and the engine is running like a six cylinder pig so needs
some drastic mapping done by the ECU distributor.
So I will have to trailer it to Maidstone & Surbiton workshops in one day as it is not driveable until these are done ........ THEN I will drive
it to SVA - but not my local centre as the Gillingham SVA is familiar with my car and is less likely to be picky (plus I get an hour's driving
in too!)
[Edited on 27-7-06 by RazMan]
Raz
907
| posted on 27/7/06 at 06:00 PM |
19" to the top of the ball is the standard height I believe.
That's what mine is and it's a main dealer fitted one.
Paul G
DIY Si
| posted on 27/7/06 at 06:02 PM |
Fair enough. Just seemed (to me anyway) that you needed one to get you to the sva. How come the engines not running right yet?!
RazMan
| posted on 27/7/06 at 07:47 PM |
My Duratec is only the second one that the MBE ECU distributor has set up - and mine is a little different from the average. It has got SVT upper
& lower manifolds, bigger injectors and modified throttle bodies, so the base map just isn't close to what I need. Hopefully it will give me
about 220bhp (300 with NO2 ) after a good map has been written for it.
Raz
RazMan
| posted on 27/7/06 at 07:51 PM |
ooh how quaint - inches! You must be as old as me
480mm is about what I have so at least I know I can hitch up to a trailer when the time comes.
Raz
907
| posted on 27/7/06 at 08:23 PM |
Funny this old metric / imperial thing.
We have chassis made from 25 x 25 box,
and yet we have 2" exhaust pipes.
atb
Paul G
RazMan
| posted on 27/7/06 at 08:26 PM |
LOL I just looked at your profile and you ARE as old as me .... well almost
Raz
907
| posted on 27/7/06 at 08:29 PM |
It was a good year
| posted on 29/7/06 at 10:33 PM |
the one on my old car was 16" to the top of the ball. My trailer is designed around this.
Mark Allanson
| posted on 29/7/06 at 10:53 PM |
The ball centre (50mm) must coincide with the most sensitive part of the male human shin.
Just try out a few in Sainsbury's car park to check
owelly
| posted on 30/7/06 at 06:44 PM |
Hmmm. I've built all my trailers to be 14 1/2" to the centre of the ball. It seems to work for me but my big 4wheeled plant trailer is
exactly 15" to the COB when level. It makes it rattle when it's empty!
[Edited on 30/7/06 by owelly]
http://www.ppcmag.co.uk
