Author: Subject: If i could fit a new engine............
Major Stare
posted on 23/11/06 at 08:30 PM Reply With Quote
it would be this....
Jon "FISH"
posted on 23/11/06 at 09:23 PM Reply With Quote
Nice - 2.5L Turbo as used in the Focus ST?
Major Stare
posted on 23/11/06 at 10:15 PM Reply With Quote
Yup
Jon "FISH"
Stu16v
posted on 23/11/06 at 10:28 PM Reply With Quote
Does it have Volvo on the rocker cover when it is in the Focus too?
Volvorsport
posted on 23/11/06 at 11:11 PM Reply With Quote
youll now see my ramblings arent unfounded , in fact the 2.5 litre engine is a pansy and wont take the same power as a 2.3 volvo lump , open deck block , thin cylinder walls .
its a shame really its taken a ford POS to raise the awareness that is a whiteblock volvo engine , which is weaker than a volvo redblock in its std form
www.dbsmotorsport.co.uk
getting dirty under a bus
Simon
posted on 23/11/06 at 11:58 PM Reply With Quote
http://cgi.ebay.co.uk/FORD-FOCUS-ST-TURBO-ENGINE_W0QQitemZ250049834744QQihZ015QQcategoryZ21654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Simon
goodall
posted on 24/11/06 at 12:26 PM Reply With Quote
it is infact an audi engine. used in the audi quattro ur and many other audi's in the 1980's and early 1990's.
volvo developed the engine with porsche, who developed the audi engine because porsche are part of VAG. porsche just pretty much copied the audi engine i'm lead to believe.
lamborghini who are part of VAG now have developed a V10 version of the audi 5
gazza285
posted on 25/11/06 at 07:22 AM Reply With Quote
Are you sure about this one? The five cylinder engine was a joint venture, but was originally designed as a straight six engine which then had one and then two cylinders removed to form the five and four cylinder variants. The designs of the blocks are completely different, with the Audi having main bearing caps and the Volvo having a complete crank carrier section. The head designs are also completely different as the Quatrro only had one cam, and non crossflow, unless it was a five valve per cylinder DOHC head while the Volvo has either a four valve per cylinder or a two valve per cylinder, both with two cams. Different bore and strokes too. They did both have five cylinders though.
Volvorsport
posted on 25/11/06 at 09:58 AM Reply With Quote
as above ^^^^
thats a misnomer that its an audi engine .
it has a more modern lower crank case - pretty much like how millington updated the ageing pinto/cosworth design !!!
and since this engine has been available from 1992 , and in 2.3 guise is a much better potential for use than the overpriced 2.5 ford thingy . basically £300 would get you that engine out of a T5 .
goodall
posted on 26/11/06 at 10:51 PM Reply With Quote
no what i ment was that the people who made the engine for both companys were porsche and that all they had to do was develop what they had already made for audi to make the volvo engine. sorry i shoulden't have put my little bit of spin on it!!!
audi did have a 20v model of the engine it was mainly fited to the 200 and the coupe
but from what i've heard some of the castings have vag on then, but i'm not sure to believe this
[Edited on 26/11/06 by goodall]
gazza285
posted on 27/11/06 at 03:59 AM Reply With Quote
Volvo did use the VW Diesel engines before they had the D5 engine, including the Godawful five cylinder one. Cracked head anyone?
Volvorsport
posted on 27/11/06 at 06:43 PM Reply With Quote
it bears no resemblence to an audi engine , sorry .
