Author: Subject: Oil and Power steering Fluid
greggors84
posted on 21/3/07 at 07:33 PM Reply With Quote
My dad has managed to top up the oil in his mondeo via the power steering reservior! (The nearest cap to the dipstick)
Ive syringed nearly all of the fluid out of the reservoir, but it looks very like powersteering fluid, not oil (red in colour) looks like the oil is heavier as I worried and has sunk down the pipe.
The car hasnt been run since he put the oil in. If I managed to get the hoses off where they go into the pump and into the rack and get the fluid out will it be enough?
Or will just above the pump be enough?
How different are the fluids?
How much shall i charge for the service!
Chris
The Magnificent 7!
posted on 21/3/07 at 07:50 PM Reply With Quote
You could try removing reservoir and flushing out with brake cleaner then refill with fresh fluid
posted on 21/3/07 at 07:55 PM Reply With Quote
i ran my van for ages with oil instead of ps fluid, no harm that i saw.
posted on 21/3/07 at 08:03 PM Reply With Quote
Unlikely to do any harm, ATF is a mineral oil with viscosity not far off Zetec spec engine oil.
Chippy
posted on 21/3/07 at 08:04 PM Reply With Quote
If memory serves, the two are pretty similar, (both being an oil), diference is that engine oil is more viscous than PS fluid. If you refill the reservoir with fresh fluid, over a period they will combine, and everything should work fine. IMHO Ray
Blast, beat me to it. Memo to self, must type faster.
[Edited on 21-3-07 by Chippy]
greggors84
posted on 21/3/07 at 08:23 PM Reply With Quote
Thanks for the replies, very reassuring!
By the way its a Duratec, but im sure the oil isnt different!
Chris
The Magnificent 7!
posted on 21/3/07 at 08:29 PM Reply With Quote
Think the Duratec version uses a special fluid for the PAS not ATF.
greggors84
posted on 22/3/07 at 03:41 AM Reply With Quote
ATF? I always took that to be Automatic Transmission Fluid am I wrong? Or is this similar to PAS fluid?
Ive drained the fluid up to the pump and refilled with Ford PAS fluid. Should be enough to sort it.
Chris
The Magnificent 7!
posted on 22/3/07 at 07:56 PM Reply With Quote
Most older cars used ATF in the power steering.
