DarrenW
| posted on 23/4/07 at 09:27 AM |
'97 P Peugeot 106 buyers guide
Im going to see a little Peugeot at 1pm today. Its a 60K miler, 4 door, P reg owned by an older couple for the last 3 years. All old MOT's etc,
8 months MOT, no tax (disabled). They are asking £800 for it which seems fairish ish (perhaps top book).
I know all of the obvious general things to look at when buying cars but does anyone know of any 106 specific things i should look out for?
Thanks in advance,
Darren.
gy351100
| posted on 23/4/07 at 09:43 AM |
peugeot 106
hi there
i have a pug 106 diesel n reg 130k miles
look out for:
1 wear of the rear swing arm suspension bearings
check by rocking the wheels back and forth from the top of the wheel with the car on the ground
2 drive shafts knocking on full lock especialy the near side
3 gear change linkage (i think it will be the same as petrol engine)
difficult to check without jacking up
hope you are not put off by the above
cheers keith
ko_racer
| posted on 23/4/07 at 10:35 AM |
Also check from knocks over bumps and on roundabouts.
Common for ARB bushes and drop links to be worn. Not expensive to replace.
Also check for a good idle and no hesitation on accleration. Common throttle body faults.
Also heated rear window as the relay is common to go faulty and is about £50.
Check switch gear works properly as dry joints are also common.
[Edited on 23/4/07 by ko_racer]
Mr Whippy
| posted on 23/4/07 at 11:25 AM |
You’ll lose the tax-free bit. My blue Bluebird was a disabled owners car, hence it's an auto and the outrageous 27k after 19 years . So don’t
be lead into being told that it’s a selling point. The DVLA if they find out that your fraudulently claiming will promptly take you to court.
[Edited on 23/4/07 by Mr Whippy]
DarrenW
| posted on 23/4/07 at 11:30 AM |
i will keep well inside the law and get it registered properly. Cant remember how to do it now though! Hope i dont have to take a trip to DVLA!
Ill factor the new tax into the cost. Im going to try and haggle based on this. From what ive seen there isnt too much to worry about with these
little Pugs, seem to be decent cars. The car will rarely leave our town, will mainly be used to do school runs when im away in the company car.
[Edited on 23/4/07 by DarrenW]
Mr Whippy
| posted on 23/4/07 at 11:40 AM |
I just went to the DVLA office and told them the tax on the car had changed (did it at the same time I changed the ownership) I believe there is a bit
on the form for this so you can simply send it away.
DarrenW
| posted on 23/4/07 at 12:52 PM |
What a tidy little car that turned out to be!
Not disabled tax so no hassle and vaild to end June. 2 owners. Everything works. ARB bush to change. Apart from that spot on. Interior almost like
new. A few honesty marks on the outside but generally excellent.
Mine for £775. Well chuffed. Cheapest car ive bought for a long time
Mr Whippy
| posted on 23/4/07 at 02:15 PM |
nice one, there are many amazing buys these days for very little money as the old tin worm seems to have been beaten on modern cars. I've never
been one for buying new cars as I consider them just a fulish waste of money.
