oadamo
| posted on 14/5/07 at 05:26 PM |
de dion fuk up
guess what i done i made my first de dion and i used the only tube that i could find in the factor. and mt drive shafts wont fit the flange bit
is 108mm and the tube inner dia is 106 so ive gotta make a new one
adam
Wadders
| posted on 14/5/07 at 05:52 PM |
Are you on about the hub flanges? if so there's enough meat on them to lose a bit in the lathe.
Apologies if thats not what you mean.
Al.
oadamo
| posted on 14/5/07 at 05:53 PM |
the tube where the shaft gos through into the hub
adam
mark chandler
| posted on 14/5/07 at 06:16 PM |
Split the tube and drive in a wedge, plate the gap. You know you want to bodge it !
oadamo
| posted on 14/5/07 at 06:26 PM |
if you look at where the tube is welded to you cant make the bit bigger by the bracket so iam feked
it would take me ages to grind it apart and it tuk me ages to get it perfect lol so i think ill have to make a new one
adam
[Edited on 14/5/07 by oadamo]
ayoungman
| posted on 14/5/07 at 06:33 PM |
Second time round will be quicker and probably better anyway from my experiences
"just like that !"
Wadders
| posted on 14/5/07 at 07:28 PM |
Which driveshafts are you using? IIRC the joints on mine are only 100mm diameter.
Al.
oadamo
| posted on 14/5/07 at 07:50 PM |
Al.
adam
Wadders
| posted on 14/5/07 at 07:57 PM |
Ok, fine, i give in, only trying to help.
Al.
Al.
adam
| posted on 14/5/07 at 08:48 PM |
lol
you are using bolt on sierra shafts arent you? What alan is saying is there is enough spare material on the outside of the flange to take some off and
make it fit.
oadamo
| posted on 14/5/07 at 08:59 PM |
quote: Originally posted by JoelP
lol
make it fit.
yes there bolt in bolt i would have to take a few mm off to get them to fit would this be safe
adam
Mr G
| posted on 14/5/07 at 09:00 PM |
Tripod outer joints are smaller and the likes of the mk de-dion will only take tripod (push-in) shafts. Although their diameter escapes me at the
mo.
You could mix and match a tripod outer joint with a lobro inner like the set up on billys if a tripod will go through ok.
oadamo
| posted on 14/5/07 at 09:03 PM |
haaa i get ya ill have to go to the scrapy and get some more shafts and have a fiddle to see what i can do. it would be easyer then making another
one.
adam
Mr G
| posted on 14/5/07 at 09:11 PM |
Downside will be you'll be missing caliper brackets as they are cast into the outer lobro hub assembly so you would need to buy some caliper
brackets from the likes of gts/mnr(?)
This brings up another problem of what orientation you have weled up the end plates (bolt pattern is rectangular) as the mnr brackets billy bought
won't allow a caliper to be bolted up due to it sitting in the wrong place
It never rains it pours!
If a tripod slips through you can mix and match the inner end with a lobro though
[Edited on 14/5/07 by Mr G]
NS Dev
| posted on 14/5/07 at 09:15 PM |
or you could get some ford 25 spline shafts from a std lobro jointed sierra rear end, and cut and shut these with your 28 spline shafts, so keeping
108mm joints at the inner end and 100 mm ones at the outer end
oadamo
| posted on 14/5/07 at 09:17 PM |
i made the caliper brackets then i seen that mine had them on the hubs. so ive got some already
Mr G
| posted on 14/5/07 at 09:29 PM |
Just realised by ns-dev's post and re-reading yours that your dealing with cossie gear so the mix and match I was refering to was for 25 spline
shafts.
looky
Pezza
| posted on 14/5/07 at 10:23 PM |
No idea what spline count my push in shafts were, but I manged to change the inner joints to cv joints no problem.
Just removed the tripode unit and the cv's slipped on
Saved changing my rear uprights etc to disks when using a LSD.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
andyharding
| posted on 14/6/07 at 09:31 AM |
This is exactly what I need to make for my LSD diff / DeDeon combo. Who's are these?
