wicket
| posted on 11/7/07 at 09:03 AM |
Can't write CD's
As subject. The event log shows the following entry for every failed attempt
The device, \Device\CdRom0, has a bad block
Any ideas what needs to be done to resolve the issue.
| posted on 11/7/07 at 09:11 AM |
It means the internal disc check is failing. Either there's a problem with the disc or the CD-ROM....
If it's a CD-RW its usually the disk that is shagged. If it's burning a CD-R or +R (or reading a brand new (ie unscratched CDROM)
you're having problems with it's likely the burner going wrong.
There's lots of possible fixes out there on the googlenet!!!
Some people find cleaning the lenses help, some people find doing a firmware update works, some people find a new burner works There's even a
registry hack out there that people have used....
Good luck...
ned
| posted on 11/7/07 at 09:14 AM |
sounds like writer's block to me.
boom boom
beware, I've got yellow skin
Minicooper
| posted on 11/7/07 at 09:21 AM |
What software are you using? if it's the inbuilt windows stuff, get other software and try that
wicket
| posted on 11/7/07 at 09:29 AM |
It's Sonic which on the PC when purchased
