Author: Subject: MG ZT V6 Head Gasket
rayward
posted on 23/8/07 at 11:47 PM Reply With Quote
Does anyone know if the V6 Engine used in the MG ZT has head gasket problems like the 1.8 K series?,
have heard mixed reports!
cheers
Ray
stevebubs
posted on 24/8/07 at 04:57 AM Reply With Quote
Later 800s yes but not as far as I know in 75/ZT form.
Useful site
posted on 24/8/07 at 06:49 AM Reply With Quote
Really almost completely different engine from the KV6 used in the later 800s the revised KV6 as fitted in the ZT has very few problems -- biggest one which only applies to the 2.5 is failure of the variable inlet manifold actuating motors, the symptom is a major flat spot during acceleration.
The 2.0 doesn't have this feature/problem but is a bit short on BHP little better than the 1.8 or CDTi performance wise.
Thermostats occasionally give problems as do minor water leaks as do hose clips. On all 75s the dash temperature gauge should not be trusted --- I have never seen a 75 guage read over 1/2" up the scale.
Check the cooling fans for correct operation --- should run ALMOST continuosly on low speed with AC switched on. Allow the engine to idle for a while and eventually the fan should change to high speed or switch in a second fan (depends on engine).
Check you get both sets of keys and they work the EWS security system on these cars is almost exclusively main dealer only.
Air bag warning lights showing on the dash is a common niggle caused by bad connections under the seat --- very easy to fix but returns
Be aware the cam belt interval is 96kmiles and changing the belts is not a cheap job at main dealer prices.
Only the OEM Xpart or Champion spark plugs should be fitted -- plug change interval is 60,000 miles but recommend changing at 30,000 or less with gaps set at 0.8 mm to avoid excessive HT voltages damaging the coil packs.
With automatics (JATCO 5 speed) be aware that fluid changes (using only Xpart OEM fluid) are essential for long term reliability --- this require measuring the temperature of the transmission to ensure correct filling level.
Because of the harder lower suspension the ZT feels a lot more sporting than the 75 but when pressed they both have the same eager but composed road holding. Brakers are excellent -- most owner report pad life of 60,00 miles.
Tyre wear is more of a problem particularly on the bigger wheel diameters. Tracking should be checked with the vehicle laden.
Finally I don't how often I have to say this the the 1.8 in the 75/zT dosen't have head gasket problems, it had slow water leak problems that if neglected cause loss of water circulation. The 1.8 in the Freelander is more problematic due to the installation.
[Edited on 24/8/07 by britishtrident]
nige
posted on 24/8/07 at 06:56 AM Reply With Quote
head trouble
u2u rash
he had head trouble with a v6 freelander
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
posted on 24/8/07 at 07:55 AM Reply With Quote
Originally posted by nige
u2u rash
The installation of the petrol engines on the Freelander wasn't well thought out --- they are much more prone to airlocking. Also corners were cut to drive down costs and the Land-Rover plants labour force were not renown for caring much about quality. Ford didn't adopt fairly minor modifications to the installation sugested by MG-Rover/Power Train on cost grounds.
Lift the bonnet on Freelander and it isn't much different to a Rover 214 all of the auxiliary minor parts are old BL Austin-Rover style, under the bonnet on the ZT/75 almost everything is from BMW suppliers.
posted on 24/8/07 at 09:12 AM Reply With Quote
The garage my friend bought his V6 ZT from took it back and gave him a refund, it was so unreliable. It would refuse to start for no apparent reason then fire up 3 hours later without being touched in between. It didn't overheat though
stevebubs
posted on 24/8/07 at 02:09 PM Reply With Quote
u2u rash
You're not kidding - when I took the wheel of my dad's 75 to do the brakes - all the wheel nut covers were branded "BMW"
