grassracer
| posted on 2/2/08 at 01:52 PM |
What are Anti roll bars made of
Ok I know they are usually steel but is it some kind of special stuff, looking into getting one made or better if possible making one for my Autograss
project. I know they are available from suppliers but I'm tight (sorry i mean I'm a locoster!)
NS Dev
| posted on 2/2/08 at 01:59 PM |
I use mild steel for the anti-roll bars on my grassers!
Use thickish wall seamless mild steel tube, its just the job.
Think the stuff I used was 11/16" OD by 3/16" wall.
You can use 4130 steel tube or all manner of spring steel grades, but mild will be just fine.
907
| posted on 2/2/08 at 04:30 PM |
Morris 1000 Front Springs
If I remember the Morrie Thou had torsion bar front suspension.
I can't help thinking if these could be utilized as ARB's?
Too long, too short, too fat? Maybe they could be reduced in diameter in the lathe?
Thoughts anyone?
Paul G
| posted on 2/2/08 at 05:16 PM |
Old Renault 5 used them on the rear as well, they would be nice and soft if you can find any.
Delinquent
| posted on 2/2/08 at 06:23 PM |
One of the newer Alfa's also had torsion on the front (75 maybe?) so should be a ready supply of material there!
John Bonnett
| posted on 2/2/08 at 06:38 PM |
If you can find one, try a Morris Marina anti roll bar. I shortened the arms of a Marina one and fitted it to my racing A40. It absolutely transformed
the car from being a natural over steerer to completely neutral and no roll whatsoever.
Failing that you can buy new ones in all different diameters for racing MG Midgets.
John
907
| posted on 2/2/08 at 07:45 PM |
John
John...... Shame on you..... Buy new ones indeed.
Take a thousand lines.
"To be a Locostbuilder I must THINK like a Locostbuilder"
Paul G
NS Dev
| posted on 2/2/08 at 10:31 PM |
here you go, see the grey bar in the photo on the rear of my old grasser. Made from seamless mild steel tube, warmed with a big blowlamp and bent by
hand in a vice, no pipe bender needed.
Bearings are nylon blocks drilled and split through the middle.
The drop link hangers are home made and adjustable along the "blades"
[img][/img]
John Bonnett
| posted on 3/2/08 at 08:49 AM |
Okay Mister, you've got me bang to rights. I admit everything, I'm not a Locoster I'm a spy form the S...a group.
I'll come quietly..........
| posted on 3/2/08 at 09:46 AM |
Mild steel is fine -- spring steel is best but introduces heat treatment issues so stick with mild steel.
grassracer
| posted on 3/2/08 at 05:09 PM |
Cheers guys, thats just the sort of thing I was looking for NSDev...homemade it is then
