Author: Subject: Heavy+ notchy tintop clutch
tegwin
posted on 26/2/08 at 04:01 PM Reply With Quote
I recently had my gearbox reconditioned...whilst it was out I put a new clutch, release bearing and clutch cable onto the car...
Everythig was fine, (it was done 1000 miles ago) but gradually the clutch has started to get quite heavy, which I guess I can live with...
But its notchy/sticky...if you try and bring the clutch peddle up gently its almost like something is snagging it, so its impossible to move slowly through traffic without looking like your a mad man...
Its a 2001 Polo GTI 16V 1.6.....
Anyone have any ideas what I can try and do to rectify this? its starting to drive me nuts!
www.verticalhorizonsmedia.tv
novacaine
posted on 26/2/08 at 04:03 PM Reply With Quote
release bearing/fork perhaps?
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
tegwin
posted on 26/2/08 at 04:07 PM Reply With Quote
The release bearing was replaced...
And im fairly sure that new bearings were put in the clutch actuator shaft as well...
I would take the gearbox out and see whats going on, but I would rather not given how much effort is involved... I think it took us a day to get it back in...Mainly because im a stickler for detail
[Edited on 26/2/08 by tegwin]
Mr Whippy
posted on 26/2/08 at 04:16 PM Reply With Quote
have you tried oiling the pedal pivot?
If it's a cable clutch you could fit a bar onto the clutch lever arm and move it by hand. That will tell you if it's the cable side or internal.
posted on 26/2/08 at 04:51 PM Reply With Quote
Sounds like a cable or fork pivot problem
iceman26
posted on 26/2/08 at 05:56 PM Reply With Quote
pedal box cracks cant see it until it is removed have done lots of them
adithorp
posted on 26/2/08 at 06:13 PM Reply With Quote
Ditto pedal box. Common fault on Polo's + Lopo's. PITA to change as well. That is assuming you used a quality clutch and not the cheapest you could find.
adrian
tegwin
posted on 27/2/08 at 09:33 AM Reply With Quote
It was a quality clutch I fitted...A damn expensive one at that!
I got VW to check the peddlebox and they say its fine..
It has been replaced at some point in the past with an upgraded stronger one...
I will disconect the cable and see what seems to be "catching"....If it is the cable then VW can pay to put a new one in... (they charged me over £100 to do it) They even left me their plyers inside the engine bay
