RazMan
| posted on 15/3/08 at 08:38 AM |
Resetting a Ford Escort ECU
As the title says - How do I reset the ecu? Will simply unplugging it do the trick or is it not that simple?
Also, how long does it take to 'relearn' after a reset?
ps 1995 car
[Edited on 15-3-08 by RazMan]
Raz
ch1ll1
| posted on 15/3/08 at 09:36 AM |
its plug and play,
take it for a run, steady 70ish, for a couple of miles,
then alter the speed, for a few mile
should relearn itself straight away !
you having problems with it?
can it come over to mine?
will put it on code reader if you want?(snap on)
yours paul
RazMan
| posted on 15/3/08 at 09:45 AM |
Thanks for the info Paul (and your telephone call)
Probably just me being over cautious and I just wondered if the ecu needed resetting after being traumatised by me and my soldering iron. It is
certainly running a lot better after a couple of work runs so no worries. Much better on fuel too, so I must have done something right
Raz
