mistergrumpy
| posted on 29/3/08 at 04:14 PM |
Front Axle
What do you think of this front axle design. Its from a hotrod scratch build, excellent build too have a look hereand
follow the ford 34 build. The brass bit in the middle is a bush so that each side can rotate independently but if you see it has hairpins on each
side. To me that means that if the axle twists then its working against the hairpins or am I missing summat.
[img]http://www.locostbuilders.co.uk/upload/truckchassis_036[1].jpg[/img]
Oh balls suddenly I can't do pictures again. Can anyone oblige.
[Edited on 29/3/08 by mistergrumpy]
jlparsons
| posted on 29/3/08 at 04:26 PM |
Hhmmm... I can think of a few disadvantages but I'm not sure I see any advantage? To what problem is this a solution?
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
Chippy
| posted on 29/3/08 at 04:37 PM |
Hot Rod heaven, over complicated five link beam axle. Can see several area's where that could be improved. Tried to post the picture, with no
luck, wierd!! Ray
In the words of Madge Simpson hmmmm
Without saying too much the design of the panhard link and suspension pushrod mountings on to the axle might just about work on a pedal car.
The bronze trunnion thing in the middle of the axle might be US sprint/dirt track car standard practice --- somebody on here might be able to
confirm or correct me on this.
mistergrumpy
| posted on 29/3/08 at 04:45 PM |
I think its a pure custom thing. They builders' own a custom building workshop. The idea behind it is to maintain some kind of originality that
the car once had. Things do seem a little over complicated around the front but that axle seems to be working against the hairpins I just dont get it.
The hairpins would make the upright rise up and down in an arc whilst the front axle would be, well the upright would be trying to twist against each
bar on the hairpin. Very odd.
bilbo
| posted on 29/3/08 at 05:14 PM |
[img][/img]
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
