Author: Subject: Roll Cage Padding
carpmart
posted on 21/4/08 at 08:26 PM Reply With Quote
Roll Cage Padding
Chaps
Has anyone a good (remember we are Locost Builders) source for roll cage padding?
It needs to be pretty durable and be able to accept a bit of punishment including a regular jet washing as it is going on my Drakart buggy!
Thanks in advance.
Harvey
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Dangle_kt
posted on 21/4/08 at 08:36 PM Reply With Quote
zip tie on some pipe lagging. It looks exactly like MX bar pad material, so if it works for a bar pad, it will work for a chassis rail, not sure on what the bigger sizes look like, but worth a look see.
carpmart
posted on 21/4/08 at 08:57 PM Reply With Quote
I looked at this stuff but just thought it looked a bit naff and all that! Do you know if you can get it in colours other than Grey? Black would be perfect?
H
'94 MX5 MK1, 1.8
Dangle_kt
posted on 21/4/08 at 09:04 PM Reply With Quote
heard the reference to locost and gave you the cheapest option.
You could of course get jackets made up for the foam - just like an MX bar pad, a peice of coloured plastic about 6 inches wide with a strip of velcro. not sure on cost as it would be bespoke for your bends etc.
andylancaster3000
posted on 21/4/08 at 09:29 PM Reply With Quote
I used pipe lagging, the densest stuff i could find. It doesn't stretch all the wayaround normal roll bar tube so i cut another piece in half along its length to fill the gap and wrapped it tightly with duct tape. Holds well and fairly durable. Not sure it'll take close up jet-wash action though.
Not the tidiest thing in the world and i dont suppose it'll absorb impacts overly well but it prevents damage to helmets from the occasional bumps and keeps the scruits happy.
[Edited on 21/4/08 by andylancaster3000]
iank
posted on 21/4/08 at 09:32 PM Reply With Quote
If you want it to protect in a bad off where you're helmet is bouncing off it DON'T use pipe lagging it's far too soft and isn't fireproof (afaik)
The proper stuff goes for £5-£25 a metre.
http://www.demon-tweeks.com/products/ProductDetail.asp?cls=MSPORT&pcode=LON6570
http://www.merlinmotorsport.co.uk/SHEETS-AND-TUBING-Roll-Cage-Tube-(CDS)/c321_329/p5910/ROLL-CAGE-PAD-2METRE-LENGTH/product_info.html?osCsid=19d7ba5fc 2ccd30283eb52d8fc333e2c
Anonymous
eccsmk
posted on 21/4/08 at 09:54 PM Reply With Quote
i asked about coloured pipe lagging at the plumbers merchants i use and was told i could get grey black blue and red
but on special order as they only stock grey
Confused but excited.
posted on 21/4/08 at 10:20 PM Reply With Quote
Originally posted by carpmart
Chaps
Thanks in advance.
Harvey
Heat shrink tubing to cover the padding?
You can get it up to 100mm dia. and a shrink ratio of up to 6:1 these days.
andylancaster3000
posted on 21/4/08 at 10:28 PM Reply With Quote
Chaps
Thanks in advance.
Harvey
getting it over the tubes might be a challenge in most cases though
