RichardK
| posted on 13/5/08 at 09:57 PM |
2007 Octavia VRS +15v supply
Hi gent does anybody know where on one of these I can find this on a connector under the dash, I know there is probably one off the alt but it's
buried.
It's for the relay on the towbar fridge circuit that should only come on when the circuit is charging.
It is a normal relay and not a smartcom version.
Rich
Gallery updated 11/01/2011
bigrich
| posted on 13/5/08 at 11:00 PM |
15 is the standard wiring diagram number for an ignition supply so any wire that is ignition controlled will be 15,
30 is permanent 12 volts
15 is ignition supply 12 volts
31 is earth
and lots of others i forget
