Author: Subject: Progress photos
tegwin
posted on 23/6/08 at 07:51 PM Reply With Quote
Progress photos
Some of you may remember me buying this ex F750 car a few months back....Wasnt sure what I was going to do with it...
But now its nearly complete
Almost ready for the bodywork to go back on.....It sounds amazing as well!
www.verticalhorizonsmedia.tv
speedyxjs
posted on 23/6/08 at 07:55 PM Reply With Quote
Ths FIRST thing you need to do when you get the bodywork on is POST A VID
Nice work btw
[Edited on 23-6-08 by speedyxjs]
Mark G
posted on 23/6/08 at 08:01 PM Reply With Quote
What did it look like before? or should I say what will it look like when its done?
Looks pretty interesting.
posted on 23/6/08 at 08:22 PM Reply With Quote
Looks like it should be very quick
minitici
posted on 23/6/08 at 08:32 PM Reply With Quote
Is your exhaust outlet below 60 cm from the ground?
From the photos it looks a bit high?
(Only a problem if you intend competing in the car MSA "blue book" Section C(b) 22)
blakep82
posted on 23/6/08 at 08:34 PM Reply With Quote
oooh! stunning!
not sure i like the exhaust up like that though...
________________________
MikeR
posted on 23/6/08 at 08:44 PM Reply With Quote
there appears to be quite a bit cut out around the trans tunnel - is there anything holding the prop at bay should the worst happen?
lsdweb
posted on 23/6/08 at 08:45 PM Reply With Quote
Tegwin
It looks so right! You've been busy.
One tiny comment - I hate those plastic switches!
Keep up the good work!
Wyn
Miks15
posted on 23/6/08 at 09:22 PM Reply With Quote
that looks amazing
and i like the exhaust like that!
is it going to be sticking out of the bodywork?
tegwin
posted on 23/6/08 at 09:27 PM Reply With Quote
Chears all.
The plastic switches may look sh*te but they are cheap and functional!
The exhaust does look much better in real life. Ideally I would have had a custom exhaust created so that the silencer would exit out of the side of the car, sadly funds do not permit. The exit should be pretty much 600mm when the car is on the ground!
There is a solid steel plate between the drivers legs and the prop as well as 5 box section retaining "straps". On top of that there is an ali/fibreglass tunnel. That should offer plenty of protection for most eventualities! (And yes I have seen the pictures of what happens when it goes wrong!)
This is what the bodywork looked like on the origional car:
[Edited on 23/6/08 by tegwin]
Daimo_45
posted on 23/6/08 at 11:56 PM Reply With Quote
sweeeet
worX
posted on 24/6/08 at 05:15 AM Reply With Quote
STILL Very jealous - I so wanted to buy that when we saw it on PH!
