Author: Subject: Using power steering without the power steering?
speedyxjs
posted on 2/10/08 at 09:20 AM Reply With Quote
To keep costs down, im planning to use my donor steering. Problem is its power steering. Sure i could have power steering in a locost but a) its added weight and b) does one really need power steering in a car that weigh's (hopefully ) less than 1 ton?
What options, if any, do i have other than buying a new, non powered one?
tegwin
posted on 2/10/08 at 09:23 AM Reply With Quote
The ratios in power steering racks are not suitable to be used with no hydraulics...
The steering would be heavy... have you ever tried to turn the wheel of a power steered car with the enigne off whilst moving?...its hard!
www.verticalhorizonsmedia.tv
loggyboy
posted on 2/10/08 at 09:27 AM Reply With Quote
If it wasnt plumbed in it would fail the MoT. However if this wasnt an issue it wouldnt be any harder to turn than a car with a quick rack.
Mistral Motorsport
Mr Whippy
What are you like? why don't you just buy a second hand rack or get one from the scrappy rather than run a powered rack without an oil supply, damn thing is likely to seize and I doubt an MOT inspector would ever pass that far less the SVA guy.
btw I love the cost saving approach to building a car that will need your own oil well to run
loggyboy
posted on 2/10/08 at 09:31 AM Reply With Quote
If you want a quick rack and light steering then fit an EPAS column from a Corsa or similar.
Mistral Motorsport
smart51
posted on 2/10/08 at 09:35 AM Reply With Quote
Hydraulic steering racks are designed to run full of oil. You can't run them without. You have to have a circuit to move the oil as you turn or you'll have hydraulic lock. Think of a hydraulic steering rack as two hydraulic rams with a rack and pinion in them. The rack and pinion is secondary to the hydraulics.
You have to buy a manual steering rack.
loggyboy
posted on 2/10/08 at 09:40 AM Reply With Quote
I dont think his intention was to run it dry, he was planning on fitting the full system.
If you did want to thos this you could get an Electric PAS pump from a saxo/106 that would allow you to run the system without having to link the pas pump to the engine.
Mistral Motorsport
speedyxjs
posted on 2/10/08 at 09:47 AM Reply With Quote
Thats right. I would struggle to find a non powered rack of the right width
matt_claydon
posted on 2/10/08 at 09:54 AM Reply With Quote
With that bloody great engine over the front wheels I would have thought PAS would be a good idea! Then you can have a nice quick rack without the steering being very heavy.
smart51
posted on 2/10/08 at 09:58 AM Reply With Quote
In that case, you have 2 options. Connect the PAS to the pump on the engine. Connect the pas to an electric pump. I think the polo had one. Some electric pumps run a 2 speeds, slow when there is little steering and fast when there is a lot.
Hydraulic has a valve in the column. The more torque you apply to the wheel, the more the valve opens, sending pressure to the rack. This hydraulic pressure assists you in the steering. The assistance is governed by the stiffness of the torsion spring in the column and the opening profile of the valve. It is not advisable to do a DIY change on either. Whatever assistance ratio the system is set up to give, is what you get.
I'm guessing now but if you geared the pump down a bit, you would have less hydraulic pressure and perhaps less assistance. Maybe.
trogdor
posted on 2/10/08 at 10:06 AM Reply With Quote
I drove my astravan back from devon with no power steering after the power steering pump belt had to be cut off by the AA man to refit the alternator one behind it. He said it would be fine, am not amused if it could of broken my steering apart from the fun of driving it home like that, fine on the motorway not fun on roundabouts or parking.
Its not nice to drive it like that trust me. The AA man also lied about rounded power steering pump bolts, just didn't want to get on his back to fix it, so i had too. If it had been my wife driving the car rather than me i would of made him tow us back as there would of been a good chance of her crashing, I nearly did a few times!
I think i have ranted about this before on here so will stop now.
[Edited on 2/10/08 by trogdor]
Mr Whippy
posted on 2/10/08 at 11:01 AM Reply With Quote
then why did you head the post as -
anyway, I still have my doubts the earths crust can support the cars weight...
speedyxjs
posted on 2/10/08 at 11:17 AM Reply With Quote
I didnt know if there was any way to use it without the power. I heard something about just putting fluid in the rack and joining the pipes (or something like that) and didnt know if it was true
donut
posted on 2/10/08 at 11:32 AM Reply With Quote
Although you really should buy a proper rack i admire you for thinking Locost!!
speedyxjs
posted on 2/10/08 at 12:12 PM Reply With Quote
I have to. I need another car and am getting a race license in a few months
Liam
posted on 2/10/08 at 12:52 PM Reply With Quote
Huh how come? How wide is your chassis at the front wishbone mounts? It's the inner pivot points of the rack that really matter so you can dial out bump steer. Overall width is a non-issue as you can extend the track rods. I'd be surprised if a non-powered sierra rack or something even narrower didn't turn out to be ideal.
If it really isn't, back in the days when men were men (about L/M reg) you could get a transit van with no power steering. That was fun to park . That be wide enough for ya?
Liam
liam.mccaffrey
posted on 2/10/08 at 04:07 PM Reply With Quote
in keith tanners book and on his website he details the steps and mods he made to his miata pas rack, ill see if i can find the page
http://www.cheapsportscar.net/diary.php?UID=6
his description in the book is more in depth
Build Blog
Build Photo Album
