chris_smith
| posted on 7/10/08 at 11:38 AM |
starting problem
my wifes daily driver has decided to play up, seat alhambra 1.9tdi S-Reg, never had a problem in nearly 3 years.
tried to start and all i got was starter trying almost as if battery was flat, no switches left on so no reason to be flat, tried jumping to no avail,
the jump leads i have arent great so took battery off charged over night, tried again and nothing, doesnt even try to turn over
i can hear the relays clicking so is it my starter thats goosed, have put in gear and rocked thought maybe starter had locked, that didnt help , have
i missed something
please help
chris
Mr Whippy
| posted on 7/10/08 at 11:43 AM |
if the headlights are still bright when left on for about 10 seconds and don't start to dim then try tapping the starter solenoid a few times
then see if it starts. Rocking the car only works if the starter is still engaged in the flywheel. If it’s not then a tap will usually make it
retract.
[Edited on 7/10/08 by Mr Whippy]
chris_smith
| posted on 7/10/08 at 11:45 AM |
not got one at home was going to take a look at weekend when i have chance to get to unit where all my tools are, will battery just die like that as
it has never once caused a problem in 3 yrs
Mr Whippy
| posted on 7/10/08 at 11:49 AM |
sometimes they do just fail if a connection inside breaks, not really all that bad life out a battery, especially if the cars been used for short
journeys.
Headlamps make just as good battery gauges
this might be a handy link -
linky
| posted on 7/10/08 at 11:52 AM |
Sounds very much Battery is knackered -- tends to be the way they die these days no warning -- with modern batteries once flattened you have a 1 in
4 chance they will take a re-charge and then only with one of the new generation chargers.
Fit new battery and check the charging voltage and also check for back current through the alternator diodes.
phoenix70
| posted on 7/10/08 at 11:54 AM |
It could be some dead cells in the battery. I had one like that, it would work just fine, but then all of a sudden it would just go completely
flat.
Also, if it is used for short journeys, the battery could of just worn out.
Scott
Chippy
| posted on 7/10/08 at 03:50 PM |
Just before you start lobbing out on a new battery, check the earths are making a good contact, plus clean both terminals on the battery. Ray
chris_smith
| posted on 7/10/08 at 07:22 PM |
ok thanks ppl for all your thoughts, i did the lights check and they were fine, i didnt think it was the battery, so with the rain dripping from all
over i took the starter out not easy as there is no room at all.
once out i could see that the small lead that goes from the solenoid to the motor was non existant completely perished, as im at work tomorrow i
called my dad who will take it to the unit and replaced said lead hopefully solving the problem
cheers
everyone
chris
