<<  1    2  >>
Author: Subject: Defective vehical dispute.
dhutch
posted on 15/6/11 at 10:50 PM Reply With Quote
Originally posted by loggyboy
Sure the answer is to fit one that does allow the bumper to be retained.
In hinds sight i should have done this a lot earlier. The origanal job was done when i was a student and a time i had very little money so having spent £80 on a OEM pug bar (used of ebay) it was somewhat annoying it didnt fit. I used it once for a one off, and put it back with a mind to modding it to fit, but then as there type approved didnt want to do that, put it back on, used it again a few times, asked the local MOT center, and it all sort of stuck. I understand the witter ones fit much better, so thats clearly the next card to play. For now its going back tow-bar less for a few weeks.
Daniel
stevebubs
posted on 15/6/11 at 11:10 PM Reply With Quote
Daniel,
If you want to U2U me, I'll put you in touch with a "local" who *may* be able to offer some advice as to how to deal with this particular copper. He may not do, but can't hurt.
Stephen
(It wasn't on the big hill you drive down as you coming to Aber, was he? That's normally where he lurks...)
[Edited on 16/6/11 by stevebubs]
dhutch
posted on 16/6/11 at 11:46 PM Reply With Quote
More details including the details of the location here:
http://forums.pepipoo.com/index.php?showtopic=62479&st=0
Dave Ashurst
posted on 17/6/11 at 06:45 AM Reply With Quote
Just an observation; the numberplate mount is in the rear bumper.
Do you still have a rear number plate with working number plate lights?
dhutch
posted on 17/6/11 at 07:32 AM Reply With Quote
The car was and is fitted with the orgianal standard size and configuartion number plate, attached to the steel work, in a very simular location to it is found when attached the to the bumper. And an alternative number plate light as been securely attached above it, wired into the existing feed. The top 10mm of the number plate was obscured with black tape.
Daniel
<<  1    2  >>
