<<  1    2  >>
Author: Subject: One for the plumbers
russbost
posted on 6/4/13 at 05:22 PM Reply With Quote
Originally posted by paulf
I have a shower with 2 central heating pumps installed, I did not want a noisy pump or to much pressure so simply fitted 2 domestic heating pumps one in the cold supply fed from the bottom of the cold tank and one into the hot outlet from the hot water tank .I did not need to use a flange outlet and dip tube as I would if fitting a higher power pump but the output is sufficient for a good shower and the pumps can hardy be heard running.
I also actually have a Stuart turner 3 bar single pump with built in flow switch
in near new condition that I was going to fit but then never used so that could be an option if your interested in buying it .
Paul
Hi Paul
The pumps you've used , do they have built in flow valves? If not, how is the syatem triggered to pump. I'm wondering if they are something like this
link
which appears to be basically a central heating pump with a flow switch fitted - this seems like it might do what I want & save messing around with surrey flange etc. so far as I can see it's intended to simply fit in line in existing pipework. Anyone ever used one of these?
paulf
posted on 8/4/13 at 08:56 AM Reply With Quote
I have used 2 normal central heating pumps with a pull switch on the ceiling to turn them on and off.I was going to fit a flow switch as well but never got around to it , even if someone forgets to turn them off after use it doesn't appear to cause a problem as have been installed for about 18 months and work fine.I did see the grundfoss ones in your link but ended up using 2 cheap tool station CH pumps ,I dont know if using one on its own would work very well as if you have mains pressure cold water and pumped hot then the pressure differential may be to great for the mixer valve to work correctly therefore I took a cold feed from the bottom of the header tank and the hot from the hot water tank outlet with the pump mounted near the bottom of the tank.
Paul
Paul
Hi Paul
link
paulf
posted on 8/4/13 at 09:03 AM Reply With Quote
Paul
Paul
Hi Paul
link
John P
posted on 8/4/13 at 10:56 AM Reply With Quote
As far as I can see that would increase the cold water pressure but your hot supply would still depend on the head created by the cold tank.
If you were considering fitting this is the flow from the hot tank then you would really still need the surrey flange to ensure the suction side of the pump doesn't draw in air from the vent pipe.
To be honest fitting the flange isn't really difficult and as a single impellor pump can simply sit on the floor next to the hot tank there's not that much plumbing to do.
The only thing to be careful about is when removing the existing fitting from the top of the tank. I soaked mine in WD40 and it came out fairly easily, just be careful not to damage the boss which is fitted to the tank as although the treaded portion is quite strong it's only mounted on the thin copper of the tank.
John.
russbost
posted on 8/4/13 at 11:41 AM Reply With Quote
"The only thing to be careful about is when removing the existing fitting from the top of the tank. I soaked mine in WD40 and it came out fairly easily, just be careful not to damage the boss which is fitted to the tank as although the treaded portion is quite strong it's only mounted on the thin copper of the tank. "
That's the bit that was bothering me - I've played this game b4!
John P
posted on 8/4/13 at 12:25 PM Reply With Quote
Whilst I'd still do it with the correct fitting I have just come across this advice on ukplumbersforums.co.uk (No idea how sound this advice is though!)
______________________________________________________________________________________________
"Only ever fitted an Essex flange once (during training course) and had the same Surrey flange sitting on the van for nearly 4 years (still in box) .
Fitted loads of Salamander shower pumps and always tee-ed off the horizontal run off the top of the cylinder.
Cut in to horizontal run and slide on a 22mm equal tee and angle the tee down at 45 degrees to "discourage" pump aeration but giving pump hot feed primacy on system.
Continue feed in nice flowing bends where possible (or 45 degree elbows) and keep it in 22mm until just before pump then step down to 15mm at last minute as it where.
Salamander pumps are more compact than the rest and are my favourite by a country mile (you can tell by the sheer weight of them that they are solid machines). They can be squeezed into airing cupboards where others can't.
Yes,,,I know what I've said above contradicts the Salamander instructions,, but in my opinion those instructions have a degree of overkill and are written for those who may have less understanding of fluidic flows and associated systems.
_______________________________________________________________________________________________
russbost
posted on 8/4/13 at 01:08 PM Reply With Quote
Yeah, I've seen some diagrams (might be on the salamander site, I've looked at so many now it's all a bit of a blur!) where they tee into the top pipe from the tank at 45 degrees, I have to say I can't see why teeing in at 45 rather than in the vertical pipe makes it less likely to pull air in from the vent. I'm going to take a look at the whole setup tomorrow, so will have a better idea then what I can do with it!
<<  1    2  >>
