posted on 24/10/08 at 07:16 PM |
Do you know anyone with an infra-red remote temperature sensor? I know that you have a gizmo on your multimeter, but the hand-held remote temp
thingies are really useful for zipping around and checking temps here there and everywhere. I got mine from Maplins when they had a sale on - cost
around £19, I think. I've used mine for checking the temp near the temp sensor, along the pipework and at the top and bottom of the rad. Also
good for checking exhaust manifold temps (to check that they're all the same), and measuring the temp across the tyres after a fast run (good
way to check if the load is even across the tyre, i.e. the tyre pressure is OK).
As for the temps your getting - my x-flow runs at 90 degrees when moving at a decent speed, rising to around 100 degrees when sitting in traffic
queues. I don't reckon that your temps are far wrong.
posted on 24/10/08 at 08:07 PM |
Have you got ducting to force the air from the grill through the radiator rather than around it?
austin man
posted on 24/10/08 at 08:18 PM |
sorry if I missed another post an ailock could cause a sudden rise in tem on acceleration brother in law had it on his 2 litre zetec the airlock was
in the thermostat housing same place ase the temp sender. Airlock = steam = false reading quick reblead of the system and voila temperature spot on,
other than that could be faulty sender
tegwin
posted on 25/10/08 at 12:27 PM |
Chears for the input guys...
I fitted some cardboard baffles around the radiator....took the car out...and once up to temp it sat around 87 degrees for the entire trip....
It is only 10 degrees outside....but thats quite an improvement....
Need to re-fit the fan and make the baffles out of something more appropriate than cardboard!
www.verticalhorizonsmedia.tv
