Author: Subject: Source for 5/8" UNF die?
tegwin
posted on 18/11/08 at 10:27 PM Reply With Quote
Im having trouble getting the nut onto my TVR driveshafts....
The first 9mm or so takes the 5/8" unf nut perfectly... but the rest of the thread is slightly larger and wont accept the nut...
The only way I can see that I can get the nut on properly is to run a die down the thread so its all uniform at 5/8"UNF...
However, I cant find a decent quality 5/8"UNF die... there are a few on ebay ranging from £5- £15..... its only going to be used once...maybe twice...
www.verticalhorizonsmedia.tv
A1
posted on 19/11/08 at 12:43 AM Reply With Quote
try getting in touch with david gerald sportscars, they really know their stuff with the m series tvrs, might be able to help you out....
http://www.davidgeraldtvr.com/
pewe
posted on 19/11/08 at 05:50 PM Reply With Quote
Teg, try www.tracytools.com - they have some decent tools at reasonable prices.
ATB Pewe
posted on 19/11/08 at 07:44 PM Reply With Quote
Probably worth measuring the diameter of the shaft and the thread teeth per inch.A set of thread gauges cost a couple of quid , those and a Zuess chart are a good investment . The shaft may not be UNF? but unless you measure correctly you won't know.
owelly
posted on 20/11/08 at 08:49 PM Reply With Quote
I could post one to you if you promise to post it back!!??
http://www.ppcmag.co.uk
