locoboy
| posted on 20/11/08 at 09:16 PM |
air bag light tintop
Guys can anyone confirm if the air bag light not going out on the dash is an MOT fail.
I know that its not ideal to have it inoperative but my 205 doesnt have one and it passed!.
Locoboy
blakep82
| posted on 20/11/08 at 09:17 PM |
mines passed many a MOT with air bag light on
________________________
hearbear
Mine to
3.9Ltr SSC Stylus should be fun
bigrich
| posted on 20/11/08 at 09:52 PM |
the airbag system is not an MOT item,so can't fail
jacko
| posted on 20/11/08 at 10:09 PM |
My light is on and the mot is coming up soon
this light thing seam's very popular
| posted on 20/11/08 at 10:45 PM |
I think the usual trick is to take the bulb out.....
.... shortly before selling the car......
AndyO
| posted on 21/11/08 at 07:24 AM |
check the connections at the seatbelt pre tensioner under the driver seat, especially if you share the car with a taller/shorter driver. It's a
regular problem with my pug partner and this usually cures it for a week or two
| posted on 21/11/08 at 07:28 AM |
The official fix is
(1) Disconnect the battery & remove keys from vincinty of vehicle.
(2) Leave car for 15 minute before starting work to allow air bag ecu back up power supply to discharge.
(3) Find the electrical connectors under the front seats - disconnect and clean the connections with switch cleaner.
((4) Re-connect connections and battery.
[Edited on 21/11/08 by britishtrident]
speedyxjs
| posted on 21/11/08 at 07:55 AM |
Ours has been on for about 2 years now and passed 2 MOT's. Its usually (is in our case) where the seat has been moved back and forth so many
times, the connection under the seat gets dodgy.
britishtrident - Il try that with ours later as it is pretty annoying.
Not trying to change the subject but why does the airbag wire need to be connected to the seat?
martyn_16v
| posted on 21/11/08 at 09:56 AM |
Side impact airbags? Or seatbelt pre-tensioners?
Our light is on as well, has been ever since there was a dodgy connection to the steering wheel clockspring. I've got a horrible feeling it
needs plugging in to the Alfa computer to turn it off, which is why it's been on for months...
| posted on 21/11/08 at 12:26 PM |
Not many DIY software reset tools around for FIAT group cars there is one floating around but it is a bit iffy.
When my Rover 75 eventually needs replaced the choice of car will have a lot to do with what DIY tools are around for accessing the cars electronic
ystems.
