m8kwr
| posted on 22/11/08 at 11:24 AM |
Solidworks HELP
I have created a rose joint as below
  Rose Joint
But when i put a bolt through it, and mate it etc, i can get this result.
  Rose Joint with Bolt through
Does anyone know how i can limit the movement, so metal does not go through metal.
Many thanks
rost
| posted on 22/11/08 at 11:30 AM |
You can choose to stop on interference when moving a part, this is a fairly heavy process though, thats why its not enabled by default.
A Limit mate might be a solution as well, but I don't think it'll work on a rose joint.
Charlie don't surf!
bigandy
| posted on 22/11/08 at 11:37 AM |
What version of Solidworks do you have?
Depending on the version, you may be able to use a "Limit" mate. For a rose joint like this, which is basically a ball and socket, you
can define an "Angle" mates between the axis of the hole in the ball of the joint, and the axis of the socket side of the rose joint (i.e.
the main body.
When in the mate dialog box, just click on the "advanced mate" box to get to the details you need.
Hold on a moment, it is easier to describe with an example.... I'll upload one in a min (In SW 2007)
ANdy
Dammit! Too many decisions....
bigandy
| posted on 22/11/08 at 11:42 AM |
Right,
Download this zip file, and extract it to a folder somewhere. Open the assembly, and have a go at dragging the ball around. Notice how it stops at a
certain angle.
I think this is what you are after? To se ehow this has been set up, look at the mates, in particular the LimitAngle mate at the bottom.
Let me know if it is of any use, and where I should send the bill He heh!
Oh, the link might help!
www.andy-sayle.co.uk/temp/ball socket.zip
bigandy
| posted on 22/11/08 at 11:45 AM |
Oh, and you can use limit mates on angles, and dimensions. Pretty useful for assemblies that have moving parts limited by end stops (eg sliding
parts, rotating parts etc). It saves you from having to turn the Physical dynamics on when moving parts around too.
The Physical Dynamics enabled causes a hell of a load on a PC, especially if the assembly is complex. It is also pretty flakey unless you have taken
into account its "needs", which is why Solidworks have started to introduce more mates to control the same sort of things.
Interestingly, on SW2009 (not sure about 2008) there is a friction mate too..... Not really relevant here, but interesting for a geek like me!
m8kwr
| posted on 22/11/08 at 05:01 PM |
Andy - many thanks for all the assistance.
I am using SW2009.
I see what you have done, and will translate it to my parts and give it a go.
It is nice to know that hopefully (one day) that i can see exactly what my front suspension will be like, and how it acts
bigandy
| posted on 22/11/08 at 06:28 PM |
No worries. If you need any further help, give me a shout, I'm always happy to help where I can
ANdy
