Author: Subject: What did you learn today?
tegwin
posted on 29/11/08 at 09:25 PM Reply With Quote
Firstly- If you are freezing cold you make mistakes..... You really dont want the sidelights to flash when you put your foot on the brake...
Secondly... if you have cappillary guages..make sure you connect them up before starting the engine otherwise you end up with warm oil all over the inside of the car...
And finally... A 2.5L straight six engine sounds AMAZING.....And it hadnt run for nearly 8 years!
[Edited on 29/11/08 by tegwin]
www.verticalhorizonsmedia.tv
nitram38
posted on 29/11/08 at 09:35 PM Reply With Quote
Today I found out that not all Ebay buyers are a**holes.
I sold the F1-2 to someone who came around and put a £500 deposit down.
It is going by next weekend.
Simon
posted on 29/11/08 at 09:36 PM Reply With Quote
Today, for the second time in a month, I learned that an extra large donner kebab and chips really is too much
Simon
Agriv8
posted on 29/11/08 at 09:47 PM Reply With Quote
That load blancing brocade Nic's via broadcom routers in an ibm blade chasis can be real PITA becuse W2k3 server decides that it knows best !!!.
but when you know how it can be done in 4 minuites rather than 4 hours
Regards
Agriv8
posted on 29/11/08 at 10:21 PM Reply With Quote
I found out that all the Ford bellhousings (RWD) are not the same....
Expensive mistake buying a ali bellhousing for my type 9 to zetec engine
[Edited on 29/11/08 by coozer]
Paradoxia0
posted on 29/11/08 at 11:00 PM Reply With Quote
What you type into the command line on an EMC Celerra doesn't appear to happen in the web interface until a short while later... DO NOT try to do the same thing from both 'cos it doesn't look like it is working!
Oh, and gravity makes things run downhill...
Mark
[Edited on 29/11/08 by Paradoxia0]
There is no replacement for displacement...
Omni
posted on 29/11/08 at 11:11 PM Reply With Quote
That hacking an Xbox is not as easy as they make it sound on the net
O
paul the 6th
posted on 29/11/08 at 11:54 PM Reply With Quote
I learned that baby rabbits learn to trust very quickly after vicky's new pet fell asleep on my lap partly covered by a towel. The little bugger kept turning over bit by bit to get more comfy, until she was laid on her back with her legs pointing in the air and her mouth open.
She looked a bit like me after a big night...
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
omega0684
posted on 29/11/08 at 11:59 PM Reply With Quote
i found out that catching your boot on a stray piece of metal not along puts a hole in your boot but in your sock and your foot as well
oh and that 3 month old babies can't swim in the bath on their own, whoop!
posted on 30/11/08 at 12:09 AM Reply With Quote
Glenkinchie tastes nice
ReMan
posted on 30/11/08 at 01:00 AM Reply With Quote
Cobblers are now Shoe repairers
Virgin Braodband manager needs closing to allow access to other BB network.
Subway meatball with all trimmings's very nice
Roofing felt is very expensive
What an enlightening day!
graememk
posted on 30/11/08 at 01:53 AM Reply With Quote
kebabs make me fart so much i have to sleep on the sofa... 01.52 am
dogwood
posted on 30/11/08 at 08:05 AM Reply With Quote
I learned today,
I really should check the weather forecast before packing up of the night.
It has been freezing cold here for the past week, but dry and bright.
Last night we had a storm hit us,
Gale force winds, Pissing hard rain
Fuuuuuuuuugit !!!!
FREE THE ROADSTER ONE…!!
clairetoo
posted on 30/11/08 at 08:27 AM Reply With Quote
I learned that no matter how hard I work or how many hours I do , its just not enough to finish the job on time .
So I learned my boss is an ar$%hole......
Its cuz I is blond , innit
Claire xx
Will weld for food......
eznfrank
posted on 30/11/08 at 09:21 AM Reply With Quote
I found out that holding a wiring loom in your bare hand whilst slicing off the tape with a stanley knife is not a good idea!!!
posted on 30/11/08 at 10:49 AM Reply With Quote
I learnt that if you are going to fit a set of disc brakes to your bike, check that you haven't bought two left hand levers.
oh, and if you have Xlite alloy bar ends fitted, don't lean your bike against the ridge door as it will scratch it.
posted on 30/11/08 at 10:53 PM Reply With Quote
i can beat all those!
I learned that if you forget to ask for rent, your tenants will probably forget to pay! For 8 months!
Easiest 2k i ever lost
