| posted on 6/12/08 at 07:54 PM |
Steel Pipe?
I'm after some 4 or 5" steel pipe to make a chimney for my log burner.
The puka flue is way over the top expensive.. £40 for a 600mm length???
Where can I get some steel pipe, like the underground stuff utility's use? must be cheaper than the named flue gear.
Even just a short length out the burner then a coil flue pipe above that??
What have you guys used as a locost solution??
chris_smith
| posted on 6/12/08 at 08:17 PM |
get some sheet and roll one?
or if you cant roll can you make it square?
RichardK
| posted on 6/12/08 at 08:20 PM |
Probably no good Steve but I'll offer it to you, I've got a piece of 4" tube 43" long but I cut it down the middle when I made
my bonnet former! You are welcome to them but you'll have to weld em back together down the length!
Rich
Gallery updated 11/01/2011
Old hydraulic ram casing from a digger of some sort? I use to work next door to a hydraulics engineers who often had to make new rams as the old ones
were right offs, only fit for scrap.
dogwood
| posted on 6/12/08 at 08:22 PM |
Cheap as chips here.
http://www.castorama.fr/store/raccord-poele-aluminie-PLcategorie_6599.htm
Sorry no help I know
FREE THE ROADSTER ONE…!!
MkII
| posted on 6/12/08 at 09:27 PM |
i got lots at work U2U me if you dont get fixed up closer to home.m.
