Author: Subject: Weird "Whale Song" noises from Polo
trogdor
posted on 15/12/08 at 06:21 PM Reply With Quote
Hi all,
More problems, at least this time its car related! My wifes friend has brought a VW polo Mk3 I think it is. Its R reg at least!
Anyway when you pull away with a small or large amount of lock it makes groaning noises similar to "whale song" it will also make the same noise but a bit fainter at full lock at slower speeds.
There is no noise at higher speeds. If it was a rattle or knock i would say it was a CV joint. but this is a noise i haven't heard a car make! It also does it in both directions.
So any ideas at what it could be? I am assuming its to do with the suspension or steering. Any help in addition to the idea of getting a bumper sticker saying "my car speaks whale"?
theconrodkid
posted on 15/12/08 at 06:38 PM Reply With Quote
has it got pas?could be the pump,other than that look in the boot to see if there is a whale in there
who cares who wins
pass the pork pies
tomgregory2000
posted on 15/12/08 at 06:48 PM Reply With Quote
my vote is power steering related and wouldnt worry as the old mans mk4 golf makes the same noise and has done for a few years now and there has not been a problem apart from the noise, oh and the car is now up2 220K miles and no fluid has been lost or anything, i would just leave it alone and live with it
trogdor
posted on 15/12/08 at 07:09 PM Reply With Quote
yes i thought power steering too, but it is a manual rack, well that or the power steering is knackered! But i would expect the steering to be heavier than what it is! Did have a look but it was dark.
What would you expect a R reg 1.4 CL Polo to have? Would be nice if it was the pump, should be fairly easy to sort and nothing to worry about.
Mr Whippy
posted on 15/12/08 at 07:21 PM Reply With Quote
my bet is it actually does have PAS and the fluid level is low. So what your hearing is the air going through the pump bi-pass valve on full lock
trogdor
posted on 15/12/08 at 07:37 PM Reply With Quote
PAS is making sense at the mo, I may pop round and see if i can find the reservoir! would be nice if its really that simple.
The friend of my wifes asked for my help in getting her first car and i said not french, italian or from ebay. All stuff that I have done! It is a nice car tho, quite high spec for a polo.
YQUSTA
posted on 15/12/08 at 10:05 PM Reply With Quote
i had a new passat about 3 years ago did the same from new should worry
trogdor
posted on 16/12/08 at 09:09 AM Reply With Quote
well i nipped over and had a look at the car, this time with a torch, well it has power steering! The reservoir is empty so hopefully all it needs is a top up.
Thanks everyone
