Author: Subject: PC power supply - use out of pc
cadebytiger
posted on 22/12/08 at 09:51 AM Reply With Quote
As above. I am trying to use a pc power supply to power a pc fan fume extraction system on the bench. The problem I have is that the motherboard normally switches the power supply on. Does anyone know which of the big bunch of wires which normaly connect to the motherboard acts as a switch?? I guess it is a relay type job??
Thanks for any help!!
Rupert
liam.mccaffrey
posted on 22/12/08 at 09:55 AM Reply With Quote
this didn't used to be the case, older supplies used to have a hulking great switch. Now they are all soft switched.
Which is why i used to keep a few old ones
Unfortunately I can't help you though good luck
Build Blog
Build Photo Album
"To power up a stand alone PSU for testing purposes, you need to short PS_ON pin with one of the common pins. Normally, PS_ON is activated when you press and release the computer power button while it is in standby mode."
If you believe
http://www.smpspowersupply.com/connectors-pinouts.html
anyway
g.gilo
posted on 22/12/08 at 10:00 AM Reply With Quote
p/s
green to common? i seem to remember
JimSpencer
posted on 22/12/08 at 10:06 AM Reply With Quote
Hi
Have a look at this:-
http://www.rcracechat.com/vb/showthread.php?t=2129
It tells you how to turn an old ATX PSU into a basic 12v bench unit.
iank
posted on 22/12/08 at 10:28 AM Reply With Quote
One thing to be careful of is many PC power supplies don't like being run without a load on them even for a short time. In the rcracechat article the bulbs do that job.
Anonymous
f1ngers
posted on 22/12/08 at 10:34 AM Reply With Quote
Take a look at Powering on an ATX PSU without a motherboard
cadebytiger
posted on 22/12/08 at 10:36 AM Reply With Quote
Brilliant!! Thanks... Will have a read!
Benzine
posted on 22/12/08 at 10:46 AM Reply With Quote
My water pump came with an adapter to fit onto the big connector that goes to the mobo so you can test the pump system out without powering on the computer (check for leaks etc) Does the same as the link f1ngers posted
dhutch
posted on 22/12/08 at 11:30 AM Reply With Quote
Yeah, green the ground.
Only further thing, that wont affect you, if that they dont like being too unevenly loaded. So often to get a decent whack out of the 12v line they need a 100watt resistor across the 5v line.
Daniel
posted on 22/12/08 at 04:07 PM Reply With Quote
This is mine, turns the power on...
cadebytiger
posted on 22/12/08 at 07:19 PM Reply With Quote
Originally posted by JimSpencer
Hi
In this post it says to connect the 12v to the 25W bulb and the 5v to the 5W...
Should this be the other way around?
Also... is it essential to have load on the 12v, 5v and 3.3v outputs or just the 12 in order to extend its life?
Thanks for all the help
Rupert
