Author: Subject: Backyard metal casting, anyone?
blueshift
posted on 30/1/04 at 12:24 AM Reply With Quote
Recently got interested in the idea of doing a spot of casting. Always wondered how they managed to cast such complicated things as engine blocks in sand without the sand falling down etc. Found a couple of websites with locost metal casting info but nothing really comprehensive. Some enticing stuff about building your own propane smelter and casting your own lathe..
so anyway, anyone done this kind of stuff and know any good websites or books? I might trug down the library and see if they have anything.
would be kind of nifty to have a home-cast aluminium badge on one's locost, would it not? or how about home-cast knobs, handles, gearknob, etc..
Alan B
posted on 30/1/04 at 02:40 AM Reply With Quote
Search under model engineering...there are one or two books for the amateur foundryman...I have one somewhere....
Basically, there some rules of thumb, some physics and chemistry....but more common sense than rocket science.......
The model engineering gang have a similar "surely, I can make that?" mentality that Locosters have...
Don't you agree Mr Jenkins?....
andkilde
posted on 30/1/04 at 03:38 AM Reply With Quote
Not really applicable to home casting but things like cylinder heads and blocks have sand molds that are "glued" together with a two part urethane based binder. Basically you mix up a slurry of sand and the urethane binder, blow it all into a giant metal clamshell called a "corebox" with air pressure and set the urethane by pumping in a gaseous catalyst or "tea gas". The hardened core sections are assembled, molten metal poured into the voids, and the sand bashed loose with great stonking pneumatic hammers. Et voila...
Home casting is easier using the "lost wax" process. Basically, you carve the item you want to cast out of a piece of wax (rigid foam insulation is a good substitute), embed the wax in a pot of plaster of paris (or similar) and pour the molten metal into the plaster mold. Some processes molt the wax away with the hot metal, some bake it out before the metal is poured, if you use the foam it can be melted out quite cleanly with gasoline (definitely want to let it dry thoroughly before you start waving molten metal near it). Things to consider are: (a) metal needs a path in AND a path out so your mold can be fully filled, think funnel in and funnel out, both pointing up so gravity pushes all the wax & air out (b) some metals "flow" better than others, lead and bronze cast well, ali and steel can be tricky, old pistons are supposed to be a good starting point as they are made of special alloys which flow well.
Have fun, Ted
sgraber
posted on 30/1/04 at 04:07 AM Reply With Quote
Lost foam is also a neat and simple method of casting. It has been at leat 15 years since I did this so I can't remember if the foam is anything special , but it is carveable and you can glue and tape it together. Then you pack it into a container using wet sand, making sure that any high spots under the sand have a "tubeule" (new word?) of foam that vents to the surface.
When you pour molten metal, in my case aluminum, into the sand packed bucket, the metal vaporizes the foam. Let it cool for a long time, remove from sand, wash down and Viola! rough cast part.
The hardest part if I recall is preventing air bubbles from remaining in the casting. Also, as you pour the molten metal into the mould, it cools rapidly and small details at the lower portion sometimes don't get any metal.
Doing this was a LOT of fun and now I think I'd like to try it again on some bits for the car. Nothing quite like a "one-off"!
Graber
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
posted on 30/1/04 at 08:57 AM Reply With Quote
Certainly, Mr. B!
In fact, I've made quite a number of bits on the lathe for my car, where others may have made do with bought stuff...
I do know of a few books on home casting, in aluminium, brass, bronze and iron. If you can wait until this evening I'll look them up.
If you can't wait, search for books written by 'Gingery' (US books, so you have to ignore the bits on electrics if you're in the UK). Also look for 'Camden Books' or similar - there is a UK author who writes under the name of 'Chuck', but I can't remember all the details just now.
rgds,
stephen_gusterson
posted on 30/1/04 at 10:47 AM Reply With Quote
about 20 years ago I installed some equipement at volkswagens huge plant at hannover. they stamped all their own panels, made their own exhausts and did their own castings.
As has been said, they use these solid glued together sand structures. I remeber seeing some for exhaust manifolds. Look quire weird, but definatly made out of a solid sand like substance.
atb
steve
Simon
posted on 30/1/04 at 11:19 AM Reply With Quote
Chaps,
As of 1/3/04, I'll be starting my new job at my fathers art foundry. No more 2 hours on the train
Anyway, lost wax is the way we do it.
Wax orig into mould (plaster of paris/grog mix).
Web site not good, but
http://www.l-a-f.demon.co.uk/photos/photo09.htm
Is a pic of a bird in a mould showing the feed and air sprues for pouring and breathing of mould. Note all high points have an "air".
Mould is baked in the kiln for a couple of days (depending on size), until the wax has all gone. This is checked by sticking a flame under the pouring hole (moulds are upside down in kiln!). If there is smoke or a flame (burning wax gas) coming out, it ain't baked. Also, you need to ensure that all water has been removed from mould, as pouring liquid metal at 1500 deg C will instantly vapourise any moisture, will potentially dangerous consequences.
When mould baked, it's removed from kiln, turned over, covered in plastered scrim to reinforce and metal poured in.
Mould opened after a couple of hours, feeds cut off, and bronze (like I said - art foundry) put into diluted sulphuric acid bath - to break down plaster core. Then item washed out, welded, chased, coloured, waxed and polished.
Anyway, more info on site (as yet unfinished after about 4 years), so bit crap.
Also pics of casting!
Simon
[Edited on 30/1/04 by Simon]
Alan B
posted on 30/1/04 at 03:31 PM Reply With Quote
Funny how your mind works...I couldn't remember what I had for breakfast yet I recalled instantly the guy who wrote the books I was thinking of which I haven't read for 20 years (at least).....it was Terry Aspin..
http://www.amazon.com/exec/obidos/ASIN/1854861468/qid=1075469230/sr=2-1/ref=sr_2_1/002-6913643-3335256
Oh yeah...didn't have any breakfast...explains why I'm starving....
posted on 30/1/04 at 03:37 PM Reply With Quote
Well done! He was the "Chuck" I was on about...
As for Gingery, try this link:
Amazon
It doesn't tell you how to cast metal, but it does give you a way to melt it.
rgds,
timf
posted on 30/1/04 at 03:43 PM Reply With Quote
its called going senile alan
timf
posted on 30/1/04 at 03:45 PM Reply With Quote
try
http://www.visi.com/~darus/foundry/
or
http://www.backyardmetalcasting.com/index.html
for online fun in casting
very good fun using the hair dryer as an air pump to get a hotter furnace
[Edited on 30/1/04 by timf]
Alan B
posted on 30/1/04 at 03:47 PM Reply With Quote
I should say f**k off...but I'm beyond such juvenile responses....
Or am I?.....
timf
posted on 30/1/04 at 03:48 PM Reply With Quote
Or am I?.....
go on you'll feel better
chrisg
posted on 30/1/04 at 07:11 PM Reply With Quote
This brought back a few memories.
I decided that brass casting was suitable for making some classic car parts I needed but couldn't buy.
Enter one huge gas ring and a crucible.
Large amount of brass cut into small bits, and put into crucible one by one.
Cue much amazement from the assembled throng at"how much brass you have to put in before you can see it in the bottom"
Then we noticed the crack in the crucible.
£40 quids worth of brass - gone, on the plus side we were the only house on the street with a "brass inlaid" drive!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
