Author: Subject: Anyone know anything about converting JPG to Long Binary data within a dataset?
tegwin
posted on 7/1/09 at 02:43 PM Reply With Quote
I need to "import" some JPG files into an access/ MSDB file in Long Binary format...
Anyone know any way of doing it
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 7/1/09 at 02:52 PM Reply With Quote
any use?
linky
vinny1275
posted on 7/1/09 at 02:53 PM Reply With Quote
What language are you using? There must be a library for doing that already- try sourceforge.net if there isn't one built into the language / app you're using - I tend to search it with google though, as its own search doesn't always work well.....
HTH
vince
tegwin
posted on 7/1/09 at 03:35 PM Reply With Quote
English!!
All joking asside... The data sits in an MSSql database... the images are stored in that database as a link to a physical file..
I have exported from that database a CSV file which contains the usernames and links to their respective photo...
I now need to import that CSV into a piece of software... however it wont accept the links to the file directly it will only accept the images in long binary frmat...
So I dont mind what language I use I just need to change the "photo" field from a file location string to a true long binary...
Make sence... Im confused!
Looks tricky to me
http://databases.aspfaq.com/database/should-i-store-images-in-the-database-or-the-filesystem.html
mads
posted on 7/1/09 at 05:39 PM Reply With Quote
and i thought i had it difficult with some css drop-down menu code!!
got no advice but good luck!
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
tegwin
posted on 7/1/09 at 07:18 PM Reply With Quote
hmm..fudge
[Edited on 7/1/09 by tegwin]
