Stuart_B
| posted on 9/1/09 at 11:17 AM |
what to cover up my kit car with?
hi all, i am putting my kit car on a trailer wenesday night, and that is when i am getting the trailer, so i will need to cover it up for the night
and while traving to and from the sva station. and wondered what to use?
as i am not sure if the trailer will fit in the grarge.
thanks
stuart
jabbahutt
| posted on 9/1/09 at 11:21 AM |
car cover secured with bungees and if possible put some sheeets between the car and the cover in case the cover moves around slightly scratching your
car.
I went to B&Q and bought a decent length of bungee cord and once the cover fitted started at the front and lashed the whole car so the cover
couldn't really move.
Hope that helps, good luck with the SVA
Nigel
| posted on 9/1/09 at 11:43 AM |
I got a car cover in Lidl just before crimbo for £7. Bit flimsy, good for indoors, but may be ok for a night and a trip to SVA also if lashed down
properly.
Danozeman
| posted on 9/1/09 at 01:07 PM |
I took mine to sva this morning covered with a bloody great tarpaulin roped down. Perfect.
Dan
Miks15
| posted on 9/1/09 at 01:32 PM |
ive heard its bad to cover vehicles whilst driving as the blowing will rub against the paint and if theres anything between the two surfaces it will
strip the paint
Dont know how true this is
afj
| posted on 9/1/09 at 01:44 PM |
as above put an old bed sheet on first but make sure the indy and trailer is not stolen tonight
Stuart_B
| posted on 9/1/09 at 03:13 PM |
thanks for the advice, i will stick a few sheets on then a cover with bungee ropes. it will be straped down to teh trailer, but if it does fit in the
grarge it will go there, if not it will be behined 3 cars, and i will propley will not sleep or wont be able to sleep with my car out there and sva
the next day. and i live in a dead end road with all old poeple in so if a car does come down a will keep a eye open.
stuart
| posted on 9/1/09 at 07:34 PM |
Where are you based Stuart? Maybe someone can lend you one.
