posted on 9/1/09 at 09:59 PM |
tileing advice?
let's say I wanted to put down some floor tiles (ceramic) on the floor in the upstairs bathroom.
the floor itself is wooden floorboards nailed to joists and it is covered by nailed down 4 mm (?) hardboard to even the surface coz at the mo'
there are carpet tiles on top.
will this be ok for putting tiles on top? (after remiving the carptet tiles ofcourse)
i.e. will be firm enough to stop the ceramic tiles from cracking and also stop the grout between cracking as I suspect not having a solid floor will
mean there will be movement between the tiles.
Paul (Notts)
| posted on 9/1/09 at 10:03 PM |
Same as mine...I used flexible adhesive and grout, also waterproof. Been down 5 years no craks even thought I have electric underfloor heating element
under the tiles. Not sure if my board was thicker than 4mm. may have been more like 12mm.
Paul
daniel mason
| posted on 9/1/09 at 10:05 PM |
is it 4mm ply? the recommended surface for floor layer to fit to is 6mm ply,but 4mm should be fine as long as there is loads of nails in it.eg every 4
inches
| posted on 9/1/09 at 10:07 PM |
inches
4mm hardboard. Personally I'd make it more substantial/solid before laying ceramic floor tiles.
Phil
thunderace
| posted on 9/1/09 at 10:22 PM |
for bathrooms use wbp ply only 9mm and shank nails then unibond woodon floor adhesive i pva the floor first 1-10 .
you must use shank nails.
bigfoot4616
| posted on 9/1/09 at 10:29 PM |
as chris says regarding the ply. well screwed down every 6".
the 2 part flexible adhesive chris mentions is the best and what i use. it is very expensive though. you can get single part flexible that mixes with
water but i've never used it on a wooden floor.
use a proper flexible grout as well rather than putting an additive in normal grout.
[Edited on 9/1/09 by bigfoot4616]
| posted on 9/1/09 at 10:30 PM |
ok - cheers for that.
so I need to makethe floor firmer by using thicker board - what do people do about the step fromm the landing to the bathroom?
+8 mm for the board plus about 6 mm for the tiles?
jlparsons
| posted on 9/1/09 at 10:38 PM |
Top Tip!!
Fill a glass of water as full as it can without spilling (so it's slightly domed and it's only surface tension holding it) in the middle
of the floor. Now walk around it normally. If it runs down the side of the glass, your floor isn't solid enough.
I replaced my boards with 21mm exterior ply, put stringers underneath the joins and used 3 inch decking screws in predrilled holes every 4 inches. A
tradesman would use less but a tradesman doesn't have to live in your house!
Oh and the other advantage of this method is there's no step - the tiles are at the same level as the carpet.
[Edited on 9/1/09 by jlparsons]
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
bigfoot4616
| posted on 9/1/09 at 10:40 PM |
you should never use pva before tiling, use a proper primer instead. pva dries leaving a thin layer on the surface so that is all your tiles end up
stuck to.
jlparsons
| posted on 9/1/09 at 10:41 PM |
Oh, and another top tip - flexible tile adhesive aditive is just waterproof pva with an extra zero on the price tag.
bigfoot4616
| posted on 9/1/09 at 10:48 PM |
not the stuff i've seen/used.
jlparsons
| posted on 9/1/09 at 10:56 PM |
stuck to.
Unibond specify PVA primer but they state it must be 1:10 dilute and you must never let it dry before you put the adhesive down, otherwise the effect
would weaken rther than strengthen the bond.
bigfoot4616
| posted on 9/1/09 at 11:33 PM |
never used any unibond tiling products. sounds a bit of a pain if you carnt let it dry, especially if your doing large areas
eznfrank
| posted on 10/1/09 at 07:45 AM |
My old man was a tiler for 30 years or so and this is how he always did bathroom floors and is how I did mine with no probs.
Make sure you know where all your pipes run and then nail the floor down good. Then lay down a layer of expanded mesh and nail that down (if you can
do this without cutting yourself you deserve a medal!!). Then cover it with a screed of rapid set tile adhesive mixed with about 1/5th PVA so that it
almost covers the mesh. You still need to be able to just see it. Then tile on to that.
Guinness
| posted on 10/1/09 at 09:49 AM |
Sorry to hijjack the thread, but we are about to get our new en-suite in the attic conversion tiled and I'm doing the prep at the minute!
The floor is newly laid 22mm moisture resistant chipboard screwed every 250mm to new joists that are 400mm apart. Do I still need to put down another
layer of ply on top?
The walls are new bare plasterboard at the moment. SWIMBO has her heart set on Travertine for the walls and floors, but I've read on the
internet that the weight limit for bare plasterboard is less than the weight of the travertine and adhesive / grout, and that I should have fitted
tile backer board instead?
Mike
iank
| posted on 10/1/09 at 09:57 AM |
We've got travertine in our new bathroom (walls and floors) for the same reason. Bathroom fitter got through 2 diamond wheels in the cutter and
spent hours swearing about how hard to cut it was, but he did a very good job in the end.
He just glued it on to whatever wall was already there, but I didn't actually take any notice of what the original wall was made from. He put
ply down on the floorboards, but I'm fairly certain it wasn't 18mm. We'll have to see how it holds up.
Anonymous
jlparsons
| posted on 10/1/09 at 10:11 AM |
I've only done a couple of bathrooms and used unibond because my father always used it and none of his ever had any issues, but there may well
be better stuff out there. It wasn't much more work, it's very runny when that dilute so you can use a wide brush and it goes on easy. I
kept it in a jar and slapped it on each section before putting down the adhesive.
When I was researching this same topic before i did my last bathroom I eventually gave up because of the overwhelming amount of conflicting advice on
forums. I imagine if you use one of the big brand names and follow the instructions to the letter you can't go far wrong. Quite a few years on
now (depressingly many) and neither mine nor my dads have moved, touch wood!
| posted on 10/1/09 at 10:40 AM |
ideal for bathrooms is to remove the floorboards and replace with moisture resistant chipboard flooring. If screwed down regularly then i dont believe
ply is necessary. Helps keep the levels right at the door! Nailing down thin ply is pointless, the nails pull loose with time. Screw every time IMHO.
bigfoot4616
| posted on 10/1/09 at 06:52 PM |
i would still ply over it.
32kg a square meter for plasterboard, should be ok with travatine
