Author: Subject: Vauxhall 1.6 problem
oldtimer
posted on 11/1/09 at 01:57 PM Reply With Quote
Any help appreciated. My 2002 1.6 Vauxhall has an annoying intermittent problem. Sometimes it hiccups at about 3000 rpm, a spanner symbol lights on the dash and it won't rev above 3000 but keeps going quite happily below this. This is the get-you-home limiter. So, what is it. My thoughts are knock sensor or ECU. Any other thoughts?
Martin
bigrich
posted on 11/1/09 at 02:01 PM Reply With Quote
crank or cam sensor would be my first thought, although EGR valves are quite troublesome but don't generally reduce engine revs.
AndyW
posted on 11/1/09 at 05:15 PM Reply With Quote
or lambda sensor
oldtimer
posted on 11/1/09 at 05:32 PM Reply With Quote
Thanks for the replies, Looks like I may need it to be diagnosed by machine. EGR valve is at least cleanable up so I may try that first.
Regards
Martin
