james h
| posted on 6/2/09 at 02:21 AM |
Fuel line..
Will plastic/nylon 10mm p-clips be suitable to attach an 8mm (inside diameter) fuel line to the chassis?
James
Bluemoon
| posted on 6/2/09 at 08:31 AM |
Depends on the OD of the pipe!
Dan
| posted on 6/2/09 at 10:20 AM |
Copper pipe yes, rubber pipe no. Rubber pipe typically has a 16mm OD.
james h
| posted on 6/2/09 at 11:41 AM |
ok thanks, I suppose I will have to be patient and order the p-clips after getting the fuel pipe
I think the pipe will be rubber, from here:
Rally Design
I am using a carbed R1 engine, but this should be fine shouldn't it?
James
