Author: Subject: Aluminium thickness - availability
russbost
posted on 9/2/09 at 02:20 PM Reply With Quote
Ok, I'm lazy someone can surely save me some research here!
What is the thinnest commonly available aluiminium, I know you can get 1.0mm or thereabouts fairly easily, but is there anything thinner available as large sheets - I'm hoping maybe 0.5mm may exist???
dinosaurjuice
posted on 9/2/09 at 02:24 PM Reply With Quote
thinnest available is in the kitchen draw..
lowest ive ever got hold of is 0.8mm. it was from an offcut used to make composite sign.
D Beddows
posted on 9/2/09 at 02:25 PM Reply With Quote
Looking in the stockholders catalogue on my desk you can get 1050-H14 in 0.5, 0.6 and 0.8mm 2500 x 1250mm sheets
chrisg
posted on 9/2/09 at 02:30 PM Reply With Quote
The LocUst used to use 0.5mm over the medite MDF, so that should be available.
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
iank
posted on 9/2/09 at 02:31 PM Reply With Quote
Aalco sell down to 0.5mm
http://www.aalco.co.uk/
length x width x thickness weight in kg
2000 x 1000 x 0.5 2.71
2500 x 1250 x 0.5 4.23
2000 x 1000 x 0.6 3.25
2500 x 1250 x 0.6 5.08
2000 x 1000 x 0.8 4.34
2500 x 1250 x 0.8 6.78
2000 x 1000 x 1.0 5.42
2500 x 1250 x 1.0 8.47
3000 x 1250 x 1.0 10.20
2000 x 1000 x 1.2 6.50
2500 x 1250 x 1.2 10.20
3000 x 1250 x 1.2 12.20
3000 x 1500 x 1.2 14.60
2000 x 1000 x 1.5 8.13
2500 x 1250 x 1.5 12.70
3000 x 1250 x 1.5 15.20
3000 x 1500 x 1.5 18.30
[Edited on 9/2/09 by iank]
Anonymous
chris_smith
posted on 9/2/09 at 02:50 PM Reply With Quote
aalco will show it as a size they do but i call them must be 40 times a day for stock and have tried in the past to get 0.5 but rarely have it on the shelf,
iv never actually got hold of it when needed, but iv been told it is available you just have to do alot of searching, sorry i couldnt help further, you might be better with 0.7/0.8 if you can cope with the extra thickness as it should be readily available
chris
Mr Whippy
posted on 9/2/09 at 02:51 PM Reply With Quote
I've used .5 before to make a box trailer, really nice to form round curves, perfect if its just a bulkhead panel. Zero weight bearing though, even a stone thrown up by a wheel will put a big dent in it and on the trailer the wind make the panels ripple.
IIRC the Apollo moon Lander’s pressure hull was only the thickness of 5 sheets of tin foil, apparently the astronauts had to be careful not to accidentally stab it with a pen
russbost
posted on 9/2/09 at 06:23 PM Reply With Quote
Thanx chaps!
