Author: Subject: leaky garage roof
Meeerrrk
posted on 11/2/09 at 06:09 PM Reply With Quote
leaky garage roof
easiest, cheapest way to stop a tiled garage roof from leaking?
its not a gaping hole, just weeping. possibly due to the snow recently, then thawing, but it is leaking none the less.
suggestions?
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
posted on 11/2/09 at 06:13 PM Reply With Quote
depends on what is wrong.
chances are the wieght of snow has dragged a tile out of place so a push with a big stick may sort it...... but then I know FA about roofing so feel free to ignore me.
ashg
posted on 11/2/09 at 06:18 PM Reply With Quote
screw fix. £10 buys you the biggest tarp they have
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Meeerrrk
posted on 11/2/09 at 06:21 PM Reply With Quote
i did think about a tarp and some bricks!
anyone ever tried aquaseal?
posted on 11/2/09 at 06:41 PM Reply With Quote
I'm going to try it in a bit. My rented garage (flat) roof is leaking. Years worth of leak mould spring some small trees that have gone through the felt + bitumen. Take out the trees, bung in some aquaseal. Bingo (fingers crossed).
Meeerrrk
posted on 11/2/09 at 06:49 PM Reply With Quote
mines rented too, im going to try either aquaseal or thompsons roof seal tomorrow, before the car goes in.
cheers,
mark
tomblyth
posted on 11/2/09 at 08:06 PM Reply With Quote
it poo
for tiled roof ,check all tiles are seated and replace crack tiles (temp seal cracked tiles with silicon!)
Flat roofs
rented tell the landlord it's up to him
private fit EPDM roof membrain ( or have our company do it (we give 20year G/tee on waterproof) mat'l should last 50 years though! just I'd be too old to fix any problems by then!
Meeerrrk
posted on 11/2/09 at 08:19 PM Reply With Quote
landlord isnt that fussed, plus its cheap rental (now i know why lol)
quite happy to put in a bit of graft myself to fix it.
the roof is almost flat (very slightly pitched) tiled, if i get a ladder and get up there will it be safe to walk on?!
Danozeman
posted on 11/2/09 at 08:51 PM Reply With Quote
are you sure its not frozen rain and seeping in under the tiles when it thaws?
Dan
Meeerrrk
posted on 11/2/09 at 08:55 PM Reply With Quote
could well be, its a good point
tomblyth
posted on 11/2/09 at 09:21 PM Reply With Quote
use a hen walk ! just in case! take some photos !
Mal
posted on 11/2/09 at 09:25 PM Reply With Quote
Provided the tiles are overlapping properly and do not have any individual faults, such as cracks they should be waterproof.
However, if a ridge tile has come loose or moved it could be that.
As someone else said the present weather conditions may be causing thawing condensation to drip down.
Meeerrrk
posted on 11/2/09 at 09:32 PM Reply With Quote
i think it must just be that, or at least i hope. hey, ill give it a look over and a water sealing, cant hurt can it
posted on 11/2/09 at 09:40 PM Reply With Quote
Trouble is if you rent a garage they tend to pass on any costs to you IE they replace the entire roof rather than just doing a local repair and then suddenly the rent goes up 100%
Costs me an arm and a leg already (£450 per quarter not including electricity).... (for a single garage....)
Meeerrrk
posted on 11/2/09 at 10:09 PM Reply With Quote
wowsers, i thought £40/pcm was enough!
like i say im happy to put a bit of DIY in, im sure it doesnt need a new roof or anything that drastic
i hear what you say though, i can imagine getting landlord to replace roof and i end up paying for it in the long run lol
blakep82
posted on 11/2/09 at 10:17 PM Reply With Quote
tried bitumen paint on mine a few years ago. was rubbish. started peeling off in weeks, any time there's a strong wind now i end up with it all over my car... don't waste your money
________________________
Canada EH!
posted on 11/2/09 at 11:05 PM Reply With Quote
Snow and cold weather do funny things to unheated areas. Check you don't have and ice dam at the lower edge of the roof, this causes the melting snow to push under the tiles or shingles and cause leaks further up the roof, quite common here in Canada usually in the spring when snow on the roof melts.
tomblyth
posted on 12/2/09 at 12:57 AM Reply With Quote
£3.41 a week for mine glad I dont live in the south
posted on 12/2/09 at 11:13 AM Reply With Quote
If it's tiled and nearly flat there might not be enough angle for the tiles to seal and water can go uphill by capillary action if the overlap on the tiles is not big enough.
Meeerrrk
posted on 12/2/09 at 09:43 PM Reply With Quote
been looking at it today and i think it is that. the roof isnt actually leaking rain water, it just seems to be "condensated" on the roof. Im going up on the roof on saturday to take off any moss etc which will hold water, i think my car will be ok in there; ive got a proper fitted outdoor 100% waterproof cover for it.
thanks,
Mark
Meeerrrk
posted on 12/2/09 at 09:44 PM Reply With Quote
this is a valid point & it could be a contributing factor, however it doesn't "leak" rain water, it just seems to be since all this snow & heavy frosts recently
Mark
[Edited on 12/2/09 by Meeerrrk]
