locoboy
| posted on 12/2/09 at 12:26 PM |
Boiler again!
New parts being fitted for the 4th time in 2.5 years now.
Getting hacked off with it, can anyone suggest a www that i can put in my needs and it will reccommend a boiler of a certain spec to run the ammount
of rads etc that i have?
Locoboy
mookaloid
| posted on 12/2/09 at 02:27 PM |
try http://www.sedbuk.com/
and don't buy a baxi!
Worcester bosch are good.
Mark
bob tatt
| posted on 12/2/09 at 03:06 PM |
tell me how many rads, bathrooms and showers (not electric) you ahve and i will work it out for you. also is it combi, system, ot open vent.
rob
jlparsons
| posted on 12/2/09 at 06:17 PM |
Mark
Why not baxi out of interest? I'm getting a new boiler soon too, I had looked at them but have no experience of them myself. I was pretty much
decided on vaillant, are they any good?
ruskino80
| posted on 12/2/09 at 06:23 PM |
just fitted a sime murelle combi last week-5 year man warranty.most will only have 2 years.
bob tatt
| posted on 12/2/09 at 06:41 PM |
vaillant and worcester bosch are the only two i will fit. a lot of the cheaper boilers offer long warranties, which is great until you have a problem
and they cant come for a week then try to wriggle out of it. i know for a fact that both worcester and vailliant service vans have a full stock on
board. for an extra bit of cash its not worth the future hassle with cheap rubbish.
and never fit a baxi fit one when the condensors came out about 15 years ago, and baxi paid me to swap the whole boiler three times in as many years
because heat exchangers were been eaten by the condensate. ended up getting a full refund for the customer and fitting a worcester which is still
trouble free even now. you pays your money you takes your chance. one final though would you fit a cam in your engine knowing it would break a lot
easier than a slightly more expensive one.
[Edited on 12/2/09 by bob tatt]
| posted on 12/2/09 at 08:27 PM |
I have a baxi - everything works just fine apart from the hot water pre-heat, which goes wrong about once a year.
I used to have a multi-point water heater that worked well, but this boiler is just a PITA - the pre-heat's noisy, sometimes it tries to boil
the water, and quite often we turn it off at night so we can get some sleep! (it's in a cupboard on the landing).
Those two names will be noted, ready for the time when this boiler meets the great scrapheap in the sky...
locoboy
| posted on 12/2/09 at 10:07 PM |
Cheers Bob,
Its a combi.
I have 6 radiators but would probably like one to run 8 so i could add a couple more if i need to.
No shower at present but its something we are considering so it would be nice to be able to do it.
1 bathroom
Colin
Locoboy
Meeerrrk
| posted on 12/2/09 at 10:45 PM |
i have a glo-worm fitted just before xmas, along with pretty much a whole new system ££chaching££
the boiler is great, its just a shame the company who fitted it were a bunch of numptys;still trying to sort out some problems now; one being that the
flu exit in the roof isnt water tight!!
For Sale : 2008 Aries/Stuart Taylor Motorsport Locoblade (954 Blade)
bob tatt
| posted on 13/2/09 at 06:48 AM |
you need a minimum of 30kw to run that system, although if you want to add a decent shower in the future you would be better going for a 37kw cdi
worcester bosch. a little more money but well worth it. when selecting a boiler the flow rate on the hot water is more important than actual input.
you also need to look at the 35/40 degree rise figures not the 30 degree rise that a lot of the manufacturers quote, beleive me it makes a big
difference. you will also need to fit thermostatic rad valves and a minimum of a room stat or even better a programmable room stat. if you search of
the worcester web site they have registered insatllers, we can offer a five year warranty for no more money than if joe plumber does the job. any
questions just ask.
rob
DarrenW
| posted on 13/2/09 at 09:03 AM |
I had a baxi in old house. Was great for 2 - 3 years then a strange fault that turned out to be a few quid rubber diaphragm. I bet not all of the
Baxi's ever fitted have problems but its strange that they always get mentioned.
Next house got a Vaillant. As Bob says - i didnt get a choice, boiler man would only fit Vaillants.
Im told there are some other makes that come recommended too.
adam1985
| posted on 13/2/09 at 11:05 AM |
you will proberbly need the warrenty that long ha
ha
ruskino80
| posted on 14/2/09 at 10:43 AM |
yeah ha ha funny as f
