Author: Subject: bulbs!
jlparsons
posted on 14/2/09 at 11:32 PM Reply With Quote
bulbs!
So I'm driving along in the tintop and suddenly it's beeping at me... bulb gone. I was a hundred yards from a thrift shop and nipped in - bargain! - two H7 "hyperwhite" bulbs for £3!! Can't go wrong, right? Wrong. They're crap, surprise surprise, but they got me home safe and sound without exchanging paint with Mr Armco.
So now I need to change that one and I'm looking at upgrading the others while i'm there, as they've always been a bit lacklustre and I'm always driving my family around dark country lanes when I go see my folks out in mid-wales. So I need four good H7s.
Couple of questions for you lot:
1. Has anyone used "upgrade" bulbs like Osram Nightbreaker and Phillips Extreme? Are they genuinely any better than standard bulbs? I note they are all 55w, ie just the same as the standard ones... this makes me a little suspicious. Also if you have used these, are they chav blue or proper white?
2. Anyone used higher power bulbs without mishaps? I note there are stacks of 80-100w bulbs about for "offroad" driving, though I'm thinking these would probably cook some wires or even melt a reflector. What about 65w bulbs - anyone tried these?
Cheers folks!
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
tegwin
posted on 14/2/09 at 11:40 PM Reply With Quote
I use the Osram Nightbreaker on my main beams and they are noticeably better than the old ones.... They are much whiter...match the HID projector dipped lights a bit better... lol
www.verticalhorizonsmedia.tv
Simon
posted on 14/2/09 at 11:42 PM Reply With Quote
Many years ago when I had my FJ1200, I decided to try a "Xenon" bulb - it too was crap.
I then went back to shop and asked if they had anything else.
"Got these 130/90's"
Superb, especially when combined with two 55w spots
Didn't melt or blow anything, but hey these are modern times with modern materials, and twitchy manufacturers who'll probably tell you the car will go up in a ball of fire if you use anything more than a 55w bulb.
Pay your money and you take the chance I guess
Simon
dhutch
posted on 15/2/09 at 10:39 AM Reply With Quote
I put some of the Phillips X-tremes in the westfeild. Including doing a short back-to-back test.
- It was a toss up between them and the Osram Nightbreaker which although ive not tried them, are apprently simulur.
Firstly, there are not chalk and cheese, so done expect 80% more light or anything like that.
- However, they did apprear to put out a fractionall better beam pattern, and they did deffonatly give a whiter/blue, which appears brighter.
- I shone it on number of colours of board, the hedge, and the grey trailer inside from 30ft.
In summary, the diffrence is supper massive. But at £16 posted, there is a diffrence, they are a direct fit, and draw the same amount of power.
I bought mine from powerbulbs via there ebay store (search for phillips x-treame)
Daniel
posted on 15/2/09 at 10:42 AM Reply With Quote
Steve from SVC has recommended some super-bright bulbs on this forum - can't remember what type he suggested, but they were legal and E-marked, top brand and worked well.
Might be worth a search back.
jlparsons
posted on 15/2/09 at 02:00 PM Reply With Quote
did some searching - the higher the bulb efficiency the shorter the life, so it seems. So I went with mid-range ones, Osram Silverstar. 50% more than normal apparently but life not much less than normal. the 90% ones are apparently reduced to 300-400 hours mean life...
posted on 15/2/09 at 02:15 PM Reply With Quote
Absolutely, this should surprise no-one. The higher temperature you run the filament at, the sooner it's going to fail.
I put a set of Nighbreakers in my Fiat Coupe (renowned as having really terrible headlamps) and they made a very noticeable improvement. However, the Osram Silverstars I used on my last car only lasted about a year on average, so I suspect these will certainly last no longer than that. Still, they were a bit over £12 a pair from eBay, so quite happy to spend that every year for decent lights.
