theconrodkid
| posted on 10/2/04 at 01:46 PM |
compo q
right just got me a web cam,install it no probs,try to dial up internet and it says service not available,unload prog and system restore and it
works,did it twice,same result each time.any ideas???
who cares who wins
pass the pork pies
Mk-Ninja
| posted on 10/2/04 at 01:57 PM |
Maybe its the image its seeing.
I'm sure I've got one, just don't know where I've put it
Mk-Ninja
| posted on 10/2/04 at 01:58 PM |
Sorry John couldnt help it
Staple balls
| posted on 10/2/04 at 02:00 PM |
odd
what flavour of windows are you using, what webcam etc etc.
theconrodkid
| posted on 10/2/04 at 02:14 PM |
cheers ninja its xp,dunno if i poked it in the wrong hole ,its usb +one for mic and its a hi cam if that makes a diffo
who cares who wins
pass the pork pies
Staple balls
| posted on 10/2/04 at 02:39 PM |
hmmm
strange, i can't think of any obvious reasons why it should cause a problem.
how far did it get when you tried to connect?
theconrodkid
| posted on 10/2/04 at 03:05 PM |
came up with no service straight away,can usb,s be put in wrong holes ?
who cares who wins
pass the pork pies
Scotty
| posted on 10/2/04 at 03:06 PM |
no
the computer treats all usb as same
Scotty
| posted on 10/2/04 at 03:08 PM |
i have heard that messenger can be really fussy about the web cam itself, what make is it ?
theconrodkid
| posted on 10/2/04 at 03:10 PM |
make is hi cam,made in taiwan so gota be good
who cares who wins
pass the pork pies
Scotty
| posted on 10/2/04 at 03:11 PM |
mmmmmm
got any mates living close with working web cam that you could borrow to test
Mk-Ninja
| posted on 10/2/04 at 03:18 PM |
John have you checked that the USB ports are active, They can be disabled in the BIOS.
Gordon
Scotty
| posted on 10/2/04 at 03:19 PM |
if it detects the camera when plugging it in, they must be switched on
theconrodkid
| posted on 10/2/04 at 03:23 PM |
i can see my cute face on the screen so they must be working,rang the shop and he wernt really interested,ill try to load the prog again later
who cares who wins
pass the pork pies
Mk-Ninja
I didnt think it was recognising the camera, its coming up with no service straight away.
Gordon
Mk-Ninja
| posted on 10/2/04 at 03:25 PM |
oops post took too long, Im out of ideas.
theconrodkid
| posted on 10/2/04 at 03:27 PM |
somehow the cam prog is stopping the compo from connecting to the web
who cares who wins
pass the pork pies
Scotty
| posted on 10/2/04 at 03:31 PM |
i would take the web cam back and ask him to check it with messenger, assuming thats what you were using it with, as stated before i have heard of
some cam not working with messenger
theconrodkid
| posted on 10/2/04 at 03:34 PM |
cheers for yr advice chaps,he says he sells a lot of these and as most of the world uses the same compo progs i cant see them not talking to each
other,wher,s chrisw when you need him???
who cares who wins
pass the pork pies
PioneerX
| posted on 10/2/04 at 03:40 PM |
conrod,
A lot of web cams actually need a piece of software from the install Cd that links the driver to messenger. For logitec it's calle IM companion,
dont know what hitec called it.
Maybe we missed this when you loaded. The cam looks like its working as you can see yourself so the USB side is working and the windows driver.
Just a thought
Simon
simonH
| posted on 10/2/04 at 03:44 PM |
Are you using broadband with USB attached Modem (or dial up with USB modem) . if you are the web cam could be causing the modem to not work. with the
cam software installed remove the cam and try to connect to internet, if no connection then the problem is the soft ware (try to update drivers etc)
if the connection works is is probobly a power issue with the cam, try to attach to a powered hub not strait to port, or if on a passive hub connect
strait to port.
Scotty
| posted on 10/2/04 at 03:59 PM |
any bets on it being an alcatel modem ???
splitrivet
| posted on 10/2/04 at 04:20 PM |
Ive been getting tis problem a lot connecting USB devices to XP conrod,try restarting your PC after youve connected your camera
Bob
theconrodkid
| posted on 10/2/04 at 05:08 PM |
tis broadband and an alcatel modem,had cam working,turned it off and same prob,un install cam software and system restore to get back to you lucky
lot,ill wait till chrisw gets back and bribe him,thanks for yr ideas chaps
who cares who wins
pass the pork pies
Spyderman
| posted on 10/2/04 at 06:08 PM |
Are you restarting your puter after installing the camera software?
Sometimes the new software takes over all ports untill reset.
Although a lot will run straight away, most software needs a reset to configure properly.
Terry
[Edited on 10/2/04 by Spyderman]
Spyderman
