Author: Subject: tintop, honda crv, abs question, mot
welderman
posted on 9/3/09 at 10:59 AM Reply With Quote
Hi, my mum has a crv and the abs light has come on, its due an mot at the end of the month, will it fail?
If so, can i disable the light and how
Joe
Thank's, Joe
I don't stalk people
Mr Whippy
posted on 9/3/09 at 11:10 AM Reply With Quote
I had this problem with the vectra, it would fail. You could try simply removing the bulb but I'm sure they test the ABS and it’s obviously that it has it fitted
AH Ha! You just gave me an idea
stevebubs
posted on 9/3/09 at 03:31 PM Reply With Quote
Yes it will fail.
ABS if fitted is a testable component.
Taking the bulb out shouldn't work as the tester should notice it's fitted and ask why it doesn't light up when he turns the key
Phil.J
posted on 9/3/09 at 04:19 PM Reply With Quote
To get it through the MOT you can pull off the wire to the ABS light and put a temporary feed from the ignition warning light. Lights up with the ignition on, goes out when the engine starts.
Do satisfy yourself that there is nothing fundamentally wrong with the brakes first though! (It's nearly always just a faulty sensor)
