Benzine
posted on 9/3/09 at 12:23 PM |
Iveco daily turbo help
A friend of mine has an R reg 2.8 Iveco daily turbo.
I'm scared to drive anywhere in case i make it worse cos i think its metal scraping on metal inside the drum based on what i can hear. its an
iveco 2.8 turbo daily, 10 days or so ago i heard lots of nasty banging, knocking noises sounded like was coming from rear, got out and had a good look
2 or 3 times couldn't see anything wrong.........then the noises stopped, and ever since then brakes have been squealing, like i say sounds like
metal on metal, they didn't do that before
New brake shoe/pads at the rear? Why would they make a banging noise though, if they were worn out wouldn't they just start squealing? Are they
drums or discs? It'd be great if i'd be able to help him out with his problem. I'll see him later this week and I'll have to
take any tools with me, so if I have a good idea of what the problem is then I can take the right tools etc.
So any ideas on what the problem could be/anyone got one of these vans/if it is the brake shoes is it an easy enough job?
FANX
cd.thomson
| posted on 9/3/09 at 12:36 PM |
wheel bearing possibly
Craig
Danozeman
| posted on 9/3/09 at 12:57 PM |
Arnt they discs on the back with handbrake shoes in the middle of the disc drum? Is it a single wheel or twin?
Does the handrake work? These are prone to diff trouble and wheel bearings collapsing.
Also the prop u/j's will make a similar noise when they break up which may explain your banging and knocking..
Dan
Benzine
| posted on 9/3/09 at 02:31 PM |
I'll ask about the handbrake etc now and post back.
What kind of routine should I do when I get to his van? I want to make the most of my time (i'll only be there a few hours) Even if I
can't fix it it would be great if I could give him a diagnosis. I was thinking: visual inspection under the van, then maybe jack each corner up
and spin the wheels by hand to see if that reveals anything. What else can I do? If a wheel bearing has gone would it be a case of fitting a new one
or could it have damaged the housing where it sits?
Many thanks for the help so far, I'll post back later when I know if his handbrake works, twin wheels etc
cd.thomson
| posted on 9/3/09 at 02:36 PM |
wheel bearings need to be replaced ASAP to avoid damage to housing/abs sensors/wheels and to stop the whole thing falling to bits!
watch for wheel wobble when you spin the wheel.
Craig
Benzine
| posted on 9/3/09 at 02:50 PM |
Update: they are twin wheels at the back, he says the handbrake works and that there is only noise when he brakes. (i.e. no noise when just cruising
along).
Also he says: "For a while it was making banging/knocking/rattling noise all the time while i was driving, then that stopped and that's
when the squealing from the brakes started so"
Would any parts I need be easy enough to get hold of at a motorfactors?
| posted on 9/3/09 at 03:10 PM |
Sounds like a defective driver to me, I'd replace that ASAP
