Author: Subject: Frontera injectors
omega0684
posted on 10/3/09 at 09:53 AM Reply With Quote
Frontera injectors
Morning guys
mate have just rang me up saying that his dad's Frontera needs new injectors and can i have a search on the net whilst he's at work. its a 1996 2.2 petrol ecotec engine, where can i get some injectors for this car, would second hand ones be ok? oh, apparently only one is knackered but is it a case of replacing all 4? can i use the injectors off the 2.0ltr or 2.4 ltr petrol fronteras?
[Edited on 10/3/09 by omega0684]
owelly
posted on 10/3/09 at 09:57 AM Reply With Quote
Edited because I didn't read your post and I thought we were talking diesel injectors......sorry!
[Edited on 10/3/09 by owelly]
http://www.ppcmag.co.uk
omega0684
posted on 10/3/09 at 10:25 AM Reply With Quote
ebay link
would these be ok?
posted on 10/3/09 at 12:16 PM Reply With Quote
Best way to be certain is read the ID number on the side of the injectors and ask the Ebay vendor to double check that they're the same.
But yes, they should be fine.
Buying 2nd hand injectors is always a bit hit + miss. One of the "new" injectors could be duff but you'ld be very unlucky to end up with four duff ones. If they haven't been used for a while they can sometimes gum up. If this happens soaking them in injector cleaner for 24 hours can help or with the fuel rail up to pressure disconnect the electrical supply to the injector and "blip" 12v across it to free them up. Obviously don't do this too much or you'll flood the engine!!!
