omega0684
| posted on 12/3/09 at 06:14 PM |
Fuel rail dilemma
i have been installing my new adjustable fuel pressure regulator and have been pondering all day on where best to fit it, so i finally bit the bullet
and made a bracket to mount it on and installed it all. then after I removed the old fuel pressure regulator on the R1 TB's i noticed that it
had a small cylindrical insert that went into the fuel rail which had a small seal on it as well (first pic), the piece i have been sent doesn't
have this, instead it just has a recessed hole in it,pic 2, they have the same internal diameter but the new bit doesn't have the small insert
bit, where do i go from here? im after ideas on how i can seal the join at the end of the fuel rail, can i buy a straight joiner with a joiner at the
back?
clairetoo
| posted on 12/3/09 at 06:31 PM |
If you can nip over with the offending parts , I could maybe turn something up to do the job ? What you seem to need is a `thing` with the bike fuel
rail fitting one end , and an 8mm hose tail on the other , along with a couple of tabs to bolt it on with ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
omega0684
| posted on 12/3/09 at 06:39 PM |
claire that would be spot on! I can come over whenever,(but not tonight) when are you free?
clairetoo
| posted on 12/3/09 at 06:42 PM |
I'll be around all weekend , finishing stuff off.......I get away from work at 3.30 tomorrow , if you want to come early ?
Claire xx
omega0684
| posted on 12/3/09 at 06:46 PM |
ok im off out tonight to see a friend so will u2u you tomorrow if i can't find a solution.
