Author: Subject: Fiesta diesel econetic C-DPF. How does it work?
smart51
posted on 13/3/09 at 09:51 AM Reply With Quote
I'm looking for a new car for my wife and the new fiesta looks good. There's have a choice of a 1.4 and a 1.6 diesel engine, both do 63 MPG and emitt 110g of CO2, which is nice - you might as well have the bigger one.
Then there's the 1.6 ECOnetic, which seems to be exactly the same 1.6 diesel with a coated diesel particulate filter. This somehow reduces the CO2 emissions to 98g, which is good and somehow believable. It also increases the MPG to 76.
How does that work then? How does a particulate filter add 9 MPG, given that the torque and power figures are the same?
[Edited on 13-3-2009 by smart51]
Mr Whippy
posted on 13/3/09 at 09:59 AM Reply With Quote
what do you do with all the filtered particulates? does a lump of carbon fall out the back every few hundred miles?
dinosaurjuice
posted on 13/3/09 at 10:01 AM Reply With Quote
it waits until your doing a steady speed at fairly high rpm, like on the motor way. and then adds a chemical to the fuel to burn it off into something else...
theres about 3 different DPF's, i think the plated type is the best.
Phil.J
posted on 13/3/09 at 10:03 AM Reply With Quote
I suspect that the power figures are for the base engine and not taking account od the particulate filter.
Incidently, I've just taken delivery of a new 1.6 TDCi fiesta this week, cracking car and a big improvement over the last model.
hughpinder
posted on 13/3/09 at 10:22 AM Reply With Quote
The Eco model will almost certainly be running on skinny tyres, and may have different gearbox to help it along.
hugh
jonesier1
posted on 13/3/09 at 10:52 AM Reply With Quote
eco
the eco fiesta has narrower tyres diffrent gear oil ,a spoiler to reduce drag on the front etc all designed to reduce the aerodynamics and use less fuel but at an extra cost .Dpf systems put a special oil through the cat after so many drive cycles and cleans out the soot,what a lot of people dont relise they have a service life and cost a fortune to replace
owelly
posted on 13/3/09 at 11:37 AM Reply With Quote
A guy I work with had some trouble with the MIL light coming on on his Peugeot. He took it to the dealer who plugged his machine in and told him it needed a new cat and DPF. A new cat was about a billion pounds and the DPF 5 billion pounds. He had a word with one of the guys in the workshops who told him to take the DPC off the car and bake it in an oven for a couple of hours and then put it back on the car. Once fitted, rev the car hard for 10 minutes. He did all this and took the car to have the MIL put out and it's been no bother since!!!
http://www.ppcmag.co.uk
