l0rd
| posted on 22/3/09 at 12:35 AM |
Anybody Know 2
Warm air makes the engine produce less HP.
What is the increase of HP when the car is using very very cold air.
Does anyone have a diagram?
[Edited on 22/3/09 by l0rd]
stevebubs
| posted on 22/3/09 at 12:53 AM |
It's all down to air density...
Colder air is more dense than warm.
This means more air into the engine....more air means more fuel ... leads to bigger bang....
[Edited on 22/3/09 by stevebubs]
stevebubs
| posted on 22/3/09 at 01:19 AM |
PS Huge oversimplification...but it is 1am Saturday night...
DIY Si
| posted on 22/3/09 at 01:27 AM |
There is a percentage chart in the mini tuning book I have, but my scanner's down.
I can say though, that assuming the air enters the cylinder at 150 F/65 C, then lowering it to 100 F/38 C, you can expect a gain of roughly 5%.
Remember though that it is the cylinder entry temp that matters. IE a lot of heat will be absorbed from the inlet manifold, inlet tract in the head
and passing over the inlet valve itself, so having a cold feed to miles of pipe work won't have such a big effect. The theoretical maximum is 1%
gain for every 3.3 C drop in temp, but you'll get maybe 50-60% of that in practice, due to the above reasons.
Sun Tzu, The Art of War
LBMEFM
| posted on 22/3/09 at 06:20 AM |
Cold damp air is even better, more BHP on a very cold misty day. Few years back water injection was used on some high performance engines, however, it
caused problems with rusty and oil emulsifying.
| posted on 22/3/09 at 09:38 AM |
Water injection is still used in some high boost forced induction cars as a way of avoiding detonation.
I've never heard of rust being a problem due to water injection. The main problem from what I've read is that you actually need a fair bit
of water if you're going to use enough to have a significant effect and that introduces a weight penalty...
| posted on 22/3/09 at 09:58 AM |
IIRC from my college days a long time ago it's all down to volumetric efficiency? . Some engines are better than others which is what you are
trying to improve by tuning.
DIY Si
| posted on 22/3/09 at 10:08 AM |
It can do, but that's why I put my answer in percentage figures rather than saying it's worth 5HP, as it will depend on the engine.
