jlparsons
| posted on 23/3/09 at 06:41 PM |
Stone paint stripping
Ok guys, question for you!
I have a 1890s house with stone at the front (around the windws and door) that's painted. I want the paint off - a couple of neighbours have
had it sandblasted off and it looks great. But I'm not keen on shelling out £500 notes for sandblasting!
Options:
1. Use some sort of paint stripper chemicals and wash/scrape it off.
2. Use a heat gun and scraper.
Anyone tried these? Any opinions or experiences?
Thanks folks!
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during
shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to
approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable
parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television.
Keep cool; process promptly.
Keith Weiland
| posted on 23/3/09 at 06:51 PM |
I bet you could hire a sandblaster and do it yourself for a lot less.
| posted on 23/3/09 at 07:11 PM |
I've seen it done once - they were using a water-based blaster (like a pressure washer) but with sand in the water. Obviously not your usual
household pressure washer!
At the time I thought myself lucky not to be the one doing that job - very wet, messy and cold.
I wouldn't like to do it with a dry sandblaster - I reckon that the dust could be very harmful to your health. Even if you used proper grit
(i.e. not sand) the particles coming off the wall would be just as bad.
blakep82
| posted on 23/3/09 at 07:17 PM |
any photos of the area you mean? i wonder if a normal pressure washer might do it, depending on the area, type of stone etc
________________________
trextr7monkey
| posted on 23/3/09 at 07:51 PM |
Industrial steam cleaner?
Pressume if neighbours needed sand blasting paint is well attached?
stevebubs
| posted on 23/3/09 at 08:54 PM |
There's a reason they used sandblasting as opposed to any other techniques...
stevebubs
| posted on 23/3/09 at 08:55 PM |
PS you can get a sandblasting attachment for karcher pressure washers. However I would reserve judgement on how effective it would be...
jlparsons
| posted on 24/3/09 at 02:30 AM |
Will try to get a photo. Sandblaster attachment sounds interesting... i have a pressure washer!
Cheers folks. Invaluable as always!
