red22
| posted on 26/3/09 at 09:47 PM |
Any metal polishing experts about?
I've got to polish vast amounts of brass to a mirror(ish) finish and I'm trying to find out what size mop(s) to use, what speed to run it
at and what soap(s) to use. Any help much appricated. Thanks.
omega0684
| posted on 26/3/09 at 10:38 PM |
errrrrrrrr brasso?
thunderace
| posted on 26/3/09 at 11:16 PM |
what is it sheet or cast and is it lumpy in shape?
thunderace
| posted on 26/3/09 at 11:17 PM |
http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m38.l1313&_nkw=brass+polishing+kit&_sacat=See-All-Categories
red22
| posted on 27/3/09 at 12:22 AM |
"errrrrrrrr brasso?".......leaves to many swirl marks.
what is it sheet or cast and is it lumpy in shape?.......turned brass bar in a top hat shape about 2.5" dia. Need to just polish the base.
Supply of products not a problem but which products to order and technique is.
fazerruss
| posted on 27/3/09 at 07:57 AM |
I use a 6 inch wheel running off a 1425 rpm motor and Im no expert but i get very good results from almost any machined metal. Ill need to have a look
see what make the soap is it came from a iron mongers in leeds
Forum Code: Image deleted by owner
"if assholes could fly this place would be an airport"
