mangogrooveworkshop
| posted on 27/3/09 at 03:54 PM |
How to stick mercedes mags on a p100
Ford took five stud front hubs and put an adapter on to take the pcd out to 5x 160
take this adapter off and fit studs to suit the merc wheels .
Merc wheels you ask are the same pcd as five stud granny
then turn this adapter round and bolt on to the rear 5x160 turning the studs round the other way.......giving you the same smaller five stud pattern
to put the mags on......thats cool
but then we take it all off and put xr4x4 running gear and boa engine in to make a scary scary tow car
[Edited on 27-3-09 by mangogrooveworkshop]
DarrenW
| posted on 27/3/09 at 03:58 PM |
Is there a pic or link missing?
Id be bolting them on - dont think glue would be too good.
mangogrooveworkshop
| posted on 27/3/09 at 04:02 PM |
yes ther was finger problems
splitrivet
| posted on 27/3/09 at 05:13 PM |
them turn this adapter round and bolt on to the rear 5x160 turning the studs round the other way.......giving you the same smaller five stud pattern
Is this post in some sort of code cos I dont understand any of it.
Bob
steve m
| posted on 27/3/09 at 05:25 PM |
want to buy an enigma machine ??
plus i didnt understand it either
Confused but excited.
| posted on 27/3/09 at 06:42 PM |
C'mon guys it's easy.
Take the thingy off and swap the studs.
Turn it around and take the studs out again and put them back in the other way round.
Put the thingy back on the hub and bolt the new wheels on.
Sorted.
mcerd1
| posted on 27/3/09 at 06:53 PM |
Don't worry
you should be able to make some sierra 4x4 hubs with 5x112
you just a lathe and to find some granada 4x4 front hubs to go with the sierra uprights
