Author: Subject: Stolen Kit Cars
MikeLR
posted on 27/3/09 at 09:32 PM Reply With Quote
Stolen Kit Cars
There has been lots of discussion regarding anti theft devices on our cars but in reallity are many stolen . I have read about lookups being broken into, but how have kit cars being stolen ? Driven away, taken on trailer etc.
Would your usual chav type know how to steal a kit car?
Regards
Mike
blakep82
posted on 27/3/09 at 09:35 PM Reply With Quote
its probably easier to steal a kit than a production car. access to wiring etc for hotwiring.
________________________
hobzy
posted on 27/3/09 at 09:39 PM Reply With Quote
Thats why my steering wheel is in the house. Mind you, I'd challenge anyone without prior knowledge to get very far in a BEC anyway
"quick go!"
"hangon, wheres the gear stick?"
"come on they might wake up!"
"Hang on, I've stalled it"
"and again"
"b##locks and again"
"ah b#gger it lets nick that fiesta instead..."
Dangle_kt
posted on 27/3/09 at 09:53 PM Reply With Quote
i have only heard of one ever being stolen on this forum.
Compare that to the motorbike forums I frequent where there are even sections on the site dedicated to posting up about theft.
I think it would be pretty hard to sell on a kit car, they are so distinctive.
Might get them robbed and burned out though
rf900rush
posted on 27/3/09 at 09:54 PM Reply With Quote
Don't worry if they steal your BEC.
You won't need it once you have been put you in jail because fail to stop the thieves killing them selves in your car.
posted on 27/3/09 at 10:05 PM Reply With Quote
mine hasn't got any wheels on it
daniel mason
posted on 27/3/09 at 10:28 PM Reply With Quote
mine has removeable wheel with push button gear shift built in. so not only could they not steer.they could not engage 1st gear.or any gear! bar stewards.
expatkiwi
posted on 27/3/09 at 10:30 PM Reply With Quote
They would have to get mine through the house first past the very unfreindly wife
I have decided to call my Westfeild "The Caterhammer" Hopefully it will
matt.c
posted on 27/3/09 at 11:01 PM Reply With Quote
Mine has the dash on the floor Wires everywhere. I cant even get it started!
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 27/3/09 at 11:18 PM Reply With Quote
haha, thats the best one!! A pretty good safety device that.
Staple balls
posted on 27/3/09 at 11:58 PM Reply With Quote
I'd figure they should be pretty bloody easy to steal, given the fact the wiring isn't hidden nearly as well as on a production car.
However, I'd really like to see them get away with a fully built one (unfinished they'd have even less chance)
Most likely the noise of the thing starting would be fairly effective as an alarm.
Not to mention the fact SVA approved or not, I'd expect most locosts to have 4-5 anti-theft mechanisms;
Steering lock
Iginition
Immobiliser
Battery cut off
Removable steering wheel
Obviously, I'm still not convinced of the security of mine (living on the drive) but there's a van parked in front of it every night, and once it's at a point it can be moved easily, I'll probably stick a spear in the concrete and lock it to that.
A1
posted on 28/3/09 at 01:01 AM Reply With Quote
im more worried about it getting trashed...
but i leave it in gear, so hopefully the inbred poo trying to steal it wont be able to work it out, steering lock, an immobiliser and neighbors that would crucify me for starting it any time after 10 at night
James
posted on 28/3/09 at 01:28 AM Reply With Quote
There's the odd/a few posts on here about them going.
A black Indy for example that was trailered away.
I went over to mine the other day which is stashed in my girlfriends Mum's garage... found I'd left the keys in the ignition!!!
Well done Genius!
James
Ninehigh
posted on 28/3/09 at 01:52 AM Reply With Quote
Looks like I'll be installing one of them removeable wheels then. Shame we can't use more agressive anti-theft systems... I know of a good few too
t.j.
posted on 28/3/09 at 09:17 AM Reply With Quote
Just make a simple hidden "cut-off" and don't tell anybody....
And mine has no engine, no gear-box, wheels and body at the moment
BTW how come the VIN is not stamped in in every kitcar. I see a lot off "welded" on plates and have seen ones with only a VIN on the manufacturer plate. Isn't a stamped VIN "IN" the chassis needed in the UK?
How easy for someone who doesn't respect otherones property
[Edited on 28/3/09 by t.j.]
deezee
posted on 28/3/09 at 10:07 AM Reply With Quote
Years ago, I used to unhook the throttle cable and remove the HT lead / coil lead.
Although my MGB had a lock, you could probably break into that car with a potato and a pointed stick. Don't suppose it would stop anyone putting it on a trailer though.
adithorp
posted on 28/3/09 at 11:55 AM Reply With Quote
Most people weld a plate on with the VIN because if you try stamping the tube there's a good chance of denting the tube.
Once welded it is perminently part of the chassis. Yes, you could grind it off, but then you could do that anyway and restamp a number somewhere else.
Mine has igniton key...not too hard to beat but not 2 minutes either.
Immobiliser on 2 circuits...thatcham and hidden in the loom when I made it so not easy to get around.
Hidden battery cut-off...depends if you know what to look for and where (not used unless I'm away in it and it's vulnerable).
I leave it in gear...won't start unless they find neutral (I have trouble with that sometimes) and won't roll away if some kid lets the handbrake off.
If they really want it and have the time they'll get it but thats the same with anything. Best security is that they aren't familiar with it and it'll take time to figure out. Time is something that really puts them off.
adrian
http://jpsc.org.uk/forum/
pgtips
posted on 28/3/09 at 11:58 AM Reply With Quote
I use one of this bad boys. They cant get to the wheel studs and is strong as anything.
Linky
jlparsons
posted on 28/3/09 at 12:03 PM Reply With Quote
I'm with adithorp - all you can do is make it harder to steal than anything else, largely through unfamiliarity, and with our cars that ain't hard!
I'm liking the look of these keyless transponder kits too.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
snapper
posted on 28/3/09 at 12:39 PM Reply With Quote
My big worry would be if it was nicked and strippedand i got the remains back, the insurance would give me back a Pinto with Type 9, standard diff etc not the Steel flywheel, Cossy rods, V6 pistons, race head and cam, bike carbs, V6 gearbox, LSD and so on
I eat to survive
I drink to forget
mad4x4
posted on 28/3/09 at 12:58 PM Reply With Quote
Just keep a detailed document detailing all mods (with photos) and submit this to the insurance at time of taking out policy.
Then if it is nicked you will get all that back (at least in cash) .......... (well hopefully)
Scot's do it better in Kilts.
Ninehigh
posted on 28/3/09 at 06:52 PM Reply With Quote
I thought that was what the agreed value is about?
I think what I could do when I leave it at home is have a big mondeo in the way, SWMBO leaves hers unlocked most times but they'll have to get through mine to shift it, unless they're happy to nick 10p and a baby sock!
