Author: Subject: Sticking rubber to metal
speedyxjs
posted on 8/4/09 at 12:35 PM Reply With Quote
I broke one of my bump stops the other day and when i looked, they seem to just be glued on.
Is there anything i can buy to reglue them back on?
Mr Whippy
posted on 8/4/09 at 12:37 PM Reply With Quote
you need some contact adhesive, scrub off all the old glue with sand paper and the metal surface their going on.
SWW84
posted on 8/4/09 at 12:45 PM Reply With Quote
Silicone? Something like Tiger Seal?
[Edited on 8/4/09 by SWW84]
Davey D
posted on 8/4/09 at 12:46 PM Reply With Quote
Id use PU adhesive like Tigerseal, or Sikaflex. that stuff is like sh*t to a blanket
Mr Whippy
posted on 8/4/09 at 12:58 PM Reply With Quote
doesn't need a super strong bond as its under compression and held in place when in use and just sitting there when not
twybrow
posted on 8/4/09 at 01:03 PM Reply With Quote
Evostik or another similar contact adhesive (as mr whippy suggested)....
indykid
posted on 8/4/09 at 01:17 PM Reply With Quote
i used contact adhesive on my pedal pads and they dropped off in about a week, just sat there.
sika'd them on and they're still there to this day.
tom
NS Dev
posted on 9/4/09 at 06:48 PM Reply With Quote
superglue, could be made for the job.
We make automotive rubber sealing systems (i.e. window rubbers) at work and use more loctite superglue than you could imagine (as in by the gallons a day)
