Ninehigh
| posted on 12/4/09 at 02:56 AM |
Tyres, slightly bizarre
Fixed the pulling to the left problem. Got the subframe sorted, then the garage had left the back wheels with 2mm toe out! Got that all aligned and
they said it was the tyres really causing the problem.
Anyone else heard of this?
ashg
| posted on 12/4/09 at 08:05 AM |
what car?
new vectras mondeos etc are prone to it.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
| posted on 12/4/09 at 08:21 AM |
It may well be that the subframe and wheel alignment problem has caused the tyres to wear unevenly which after alignment has been corrected may still
be causing problems.
jollygreengiant
| posted on 12/4/09 at 08:46 AM |
I came across a Bedford Midi once that always pulled to the left, until, one day we balanced the front wheels on the vehicle. Go figure that one.
greggors84
| posted on 12/4/09 at 09:32 AM |
A mate changed the tyre on his Fiesta and when he put it back on it must have been slightly on an angle as it pulled to the left quite badly. Pulled
the wheel off and put it back on and it was fine.
Im guessing the extra resistance caused by wheel imbalance or worn tyres causes the car to pull to one side.
Chris
The Magnificent 7!
austin man
| posted on 12/4/09 at 11:08 AM |
Same problem on a montego the wheel wasn't sitting squarely due to rust build up in the centre
Danozeman
| posted on 12/4/09 at 02:30 PM |
if one side tread is worn more than the other it will do it aswell.
Dan
Ninehigh
| posted on 12/4/09 at 09:16 PM |
Yeah was just amusing that after all that the tyres was the last thing...
